DIY - Storage Box With Cardboard
Introduction: DIY - Storage Box With Cardboard
Hello my friends. Cardboard is an easy-to-find material and often available for free. Today I share with you how to make a storage box with cardboard.
Step 1: Tips
- We will have all 6 boxes. 4 small boxes, 1 medium box and 1 big box. We will create 4 small boxes first, then we'll create a largest box and finally create a medium box. By doing so you will not get the wrong size.
- We use adhesive tape to make the box stronger. We will fold the tape head to protect the cardboard.
- I made the box with the dimensions: 37.5 cm x 23.5 cm x 24.5 cm. It is quite close to the golden ratio, it will help our box look more balanced.
- We will let the adhesive tape out a bit on the small boxes, it's like the door knob of the box.
Step 2: Create 4 Small Boxes
Find cardboard around us. Cut cardboard with a paper cutter knife.
We'll cut 4 cardboard with the dimensions: 66.6 cm x 18.4 cm. As picture. You can create your box in a simpler way. There are many ways to create a box from cardboard.
Step 3: Create the Largest Box and Medium Box
We'll create the largest box with the dimensions: 121.7 cm x 42 cm. As picture.
- The largest box can hold 3 small boxes when placed on a flat surface. You can see this biggest box I created in a much simpler way.
- Remember to leave a space ahead.
- A medium box we do the same. This is a box twice the size of a small box.
Step 4: Finish
- We'll use a cover to divide the big box into 2 floors. We use adhesive tape to paste the cover plate.
- We'll be lining the bottom. You leave a bit of tape on each corner, which makes it easier to remove the liner.
This is our box after completion. Good luck. Thanks for reading.
Cardboard Challenge
Cardboard Challenge
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Puzzles Speed Challenge
    2 Discussions
    jessyratfink
    jessyratfink
    1 year ago
    That turned out really nicely! Very clean looking :)
    VietnamReviews
    VietnamReviews
    Reply 1 year ago
    Thank you so much my friend. Have a good day.
