DIY Super Simple Audio Amplifier
Introduction: DIY Super Simple Audio Amplifier
About: Hi my name is Steve and i'm a Creative and I got Technical skills i can build anything just stick to my account . I'm a YouTuber so you also can see my all videos here https://www.youtube.com/SteveWillsonKujur
Hey! everyone My name is Steve.
Today I'm going to show you How to Make 30 Watt Portable Amplifier in a Very Simple Way
Click Here to See The Video
Let's Start
Step 1: Features
Output Power
  • 35 Watt x 1 @ 4Ohms
Input Power
  • 16 - 24V DC
Built-in Protection
  • Over Load Protection
  • Short Circuit Protection
  • Over Heat Protection
Step 2: Thing I've Used
LCSC
Banggood
Amazon
Aliexpress
Step 3: Sponsor
Today's Article is Sponsored by lcsc.com
They are the Largest Electronics Components Supplier From China Ready to Ship within 4 Hours and they ship World Wide
Step 4: Circuit Diagram
You can see the circuit diagram to make it easier
Step 5: Soldering
You can see the image it looks messy, you can easily use perf board but in this video, I'm doing this in an easy way
  • First I've connected 22K Resistance to 2 and 4 Pin of TDA2050
  • I've connected a 22uf capacitor to the 2nd pin of TDA2050
  • 680 Ohms Resistances to the 3rd pin of TDA2050 and the negative pin of the 22uf capacitor
  • 3 22K Resistances to pin 1,3 and 5 Pin of TDA2050 and connected all the Resistance together " see the image "
  • Negative Pin of 100uf Capacitor to the 3rd pin of TDA2050 and the positive pin to the 3 Resistances
  • 2.2 Ohms Resistance to the 4th pin of TDA2050
  • 0.47uf capacitor to the 3rd pin of TDA2050 and 2.2 Ohms Resistance " see the image "
  • Negative Pin of the 2.2uf capacitor to the 1st pin of TDA2050
  • Positive pin of the 1000uf capacitor to the 4th pin of TDA2050
Step 6: Connection
Red and Black wire to 3rd and 5th Pin of TDA2050
  • Green wire to Negative of the 1000uf capacitor
  • Signal wire to Positive of the 2.2uf capacitor
Input Power
  • The black wire is ground and Red wire is Positive
Speaker Output
  • Green wire is Speaker Output with Ground
Source Input
  • Signal wire is for signal input with Ground
Step 7: Heat Dissipation
  • I used a medium size Heat Shink for Heat Dissipation with a little bit of thermal compound
Step 8: Setup and Enjoy
  • I've used a 24V SMPS to power the Amplifier
  • And used a bookshelf speaker
You Just Made It
Thank you for visiting my Instructables Stay tuned for next Projects
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    • Maps Challenge
      Maps Challenge
