DIY || Touch Controlled Home Appliances
Ever wondered to control your Home Appliances with a CLAP? Then you are at right place!
Here, I am going to show you how to control any Home Appliance be it - Room Lights, Fan, Television or Audio System with just a Touch.
This project is based on Touch ON – Touch OFF Circuit, which is a circuit which turns ON the load (lights) on touching.
Teacher Notes
Step 1: Material Required
To make this project, we require :
• 555 Timer IC
• Relay (6V)
• Diode: 1N4007
• Battery (9V) and Battery Clip
• Switch
• Wires
• PCB
• Cardboard
• Paper
• Aluminum Foil
Major Tools required:
• Soldering Iron and Solder Wire
• Hot Glue Gun
Step 2: Circuit Diagram
This circuit is basically Touch ON – Touch OFF Circuit.
Step 3: Step-by-Step Tutorial
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
