After looking for a cheap set of climbing sticks, I decided that i could make some for much cheaper than the $50+ sticks available in retail stores. These sticks are easy to make with minimal tools and materials. Once they are complete use a ratchet strap or amsteel rope to secure it to a tree.
Teacher Notes
Step 1: Gather Tools and Materials
Recommended Tools
· ½ Drill Bit
· ¼ Drill Bit
· Marker
· Tape Measure
· Drill
· Vice
· 2 Adjustable Wrenches
· Sawzall
Material List
· 1 - 2’x1” square 6160 aluminum tubing
· 5– ¼” lock nuts
· 4 – ¼”x1 ½” bolts
· 2 – ¼” washers
· 1 – ¼”x3” bolt
· 3 – ½”x6” bolts
· 3 – ½” nuts
· 3 – ½” lock washers
· 1 - 3”x3” PVC Pipe (cut in half)
Step 2: Drill Side a Holes
On Side A - Drill three ½” holes all the way through the square tubing. Drill one hole centered and the other two 1” from each end. Drill one ¼” hole 1” above the center 1/2” hole.
Step 3: Drill Side B Holes
On Side B - Drill two holes centered between the ½” holes
on the top and bottom.
Step 4: Cut PVC
Cut 3” pvc long ways making two half circle pieces.
Step 5: Drill PVC Pipe Holes
Drill ¼” holes into the pvc to match the holes drilled in step three.
Step 6: Connect PVC Pipe to Tubing
Connect the pvc pieces to the aluminum tubing using the 1 ½” bolts and lock nuts.
Step 7: Connect 3" Bolt
Put the 3” bolt through the hole drilled in step two. Tighten the lock nut half way down the threads with washers on both sides.
Step 8: Place Carriage Bolts
Put carriage bolts through the ½” holes alternating the direction that they are being put in.
Step 9: Tighten Down Carriage Bolts
Tighten the nuts down all the way down the bolt against the tubing with the lock washers wedged in-between the nut and tubing.
7 weeks ago
Nice job putting this together :)
