DIY Vacuum Adapter
1,296
Introduction: DIY Vacuum Adapter
About: I'm a self taught troublemaking woodworker that loves scroll sawing and making other random stuff and love to get dirty while doing it. I also mess in metalworking and love making sparks fly.
I recently purchased a belt sander and the vacuum adapter that came with it did not fit my shop vac, so I decided to make my own adapter from an old yogurt container.
Step 1: Gather Materials and Tools
You don't really need a lot of tools to make this adapter.
Materials
  • Quart yogurt container
that's about it...
Tools
    • hole saw-sizes 1-1/4 and 2 inch
    You may need different sizes depending on your vacuum and dust port.
    • drill or drill press
    • pen/marker
    Step 2: Cutting the Hole in the Lid
    Started by centering the adapter by eye and tracing it. I actually traced the wrong side first.) Drill a pilot hole for the center of the hole saw. Then drill out the circle. I was going to clamp it down but could not figure out a good way to do so. Instead I just went slow and kept a good hold on the cover.
    Step 3: Cutting the Hole in the Bottom
    The vacuum hose was the same diameter as the indent in the bottom of the container. This made it easier to center the hole on the container. I drilled a pilot hole again for the hole saw and drilled out the circle. There was a lot of tear out after drilling. I may have been going to fast.
    Step 4: Finished!
    Join the two pieces together and you have...A vacuum adapter!
    This design works fairly well for collecting dust but dust does build up in the "chamber".
    I also included a few variations on ways you could modify it to fit different tools.
    Thanks for reading and don't forget to vote.
    Creative Misuse Contest
    Be the First to Share
      • Mason Jar Speed Challenge
      • Bikes Challenge
        Bikes Challenge
      • Remix Contest
        Remix Contest
      2 Discussions
      chefspenser
      chefspenser
      2 years ago
      Great, simple idea-thanks for sharing!
