DIY Vinyl Record Clock
Introduction: DIY Vinyl Record Clock
Vinyl record clocks are a fun way to recycle old vinyl records that may be scratched or broken. Here is how you can make one yourself, and it is very easy.
Supplies:
-Vinyl Record 33”
-Clock Kit (Gearbox and Arms)
-Laser Cutter
-Stencil(s) of the Design(s)
-Hot Glue Gun
Step 1: Make the Design You Want on the Record
Pick the design that you want on the record and put it on the record where you want it engraved.
Step 2: Laser Engrave Your Design
Use a laser cuter to engrave the design you picked in step 1.
Step 3: Attach the Clock Kit to the Record
Once you get a clock kit, the installation is very simple. Use a hot glue gun to glue the back on and then follow the instructions as according to the picture. Then, put the battery in.
Step 4: Other Additions (optional)
The final step is adding whatever else you want to add. On mine, I put pictures from the white album gatefold and inserts.
Step 5: Finished Product
This is what you will end up with. Thank you for reading and good luck on your project!
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Puzzles Speed Challenge
