DIY Bridesmaid Jewelry- Pretty Handmade Earrings As a Gift From Bride
This DIY bridesmaid’s jewelry tutorial is a great idea for a bride-to-be. If you know one, tell her about this practical idea for preparing handmade earrings by herself as a gift to her bridesmaids!
Our DIY bridesmaid jewelry project is modern and contemporary. It’s also a great gift idea for most wedding occasions.  With this detailed description and these clear photos, even a bride with no crafting experience will find it possible to make this pair of handmade earrings by herself. It sure makes a great bridesmaid gift from bride!
Materials and tools:
Pink shell beads
Fresh water pearls
8mm white glass pearls
0.5mm silvery copper wire
Ear hooks
Round nose plier
Flat nose plier
Wire cutter
Teacher Notes
Step 1: Make the Dangles for Bridesmaid Earrings
1st, snip a piece of copper wire about 10cm long and thread it through the bottom hole of pink shell bead, white glass pearl, freshwater pearl and top hole of shell bead;
2nd, with round nose plier coil bottom wire several times;
3rd, make a wire wrapped loop at the top;
4th, cut off extra wire and repeat the process to make the second dangle.
Step 2: Finish the Earrings
Open ear hook and slide dangle onto hook.
Step 3: The Final Look Is Like Below:
Tada! This DIY bridesmaid jewelry tutorial is completed! If you’re a bride-to-be, invite your bridesmaids over to give them a pair of these handmade earrings as gifts.  They will be so happy and overcome with joy when they learn that you made these earrings yourself! These earrings will always remain an important souvenir from your wedding ceremony.
      • Indoor Lighting Contest
      • Stone Concrete and Cement Contest
      • DIY Summer Camp Contest
