DTMF Detector
292
About: I'm a software architect, self-taught mechanical engineer, passionate about science, hardware design and space research
Overview
I was inspired to build this device by a home assignment on Digital Signal Processing online course. This is a DTMF decoder implemented with Arduino UNO, it detects a digit pressed on a phone keypad in the tone mode by the sound it produces.
Step 1: Understanding the Algorithm
In DTMF each symbol is encoded with two frequencies according to the table on the picture.
The device captures input from the microphone and calculates amplitudes of eight frequencies. Two frequencies with maximum amplitudes give a row and a column of the encoded symbol.
Data acquisition
In order to perform spectrum analysis samples should be captured at a certain predictable frequency. To achieve this I used free-run ADC mode with maximum precision (prescaler 128) it gives sampling rate 9615Hz. The code below shows how to configure Arduino’s ADC.
void initADC() {
  // Init ADC; f = ( 16MHz/prescaler ) / 13 cycles/conversion
  ADMUX  = 0; // Channel sel, right-adj, use AREF pin
  ADCSRA = _BV(ADEN)  | // ADC enable
           _BV(ADSC)  | // ADC start
           _BV(ADATE) | // Auto trigger
           _BV(ADIE)  | // Interrupt enable
           _BV(ADPS2) | _BV(ADPS1) | _BV(ADPS0); // 128:1 / 13 = 9615 Hz
  ADCSRB = 0; // Free-run mode
  DIDR0  = _BV(0); // Turn off digital input for ADC pin
  TIMSK0 = 0;                // Timer0 off
And the interrupt handler looks like this
ISR(ADC_vect) {
  uint16_t sample = ADC;samples[samplePos++] = sample - 400;
  if(samplePos >= N) {
    ADCSRA &= ~_BV(ADIE); // Buffer full, interrupt off
Spectrum analysis
After collecting samples I calculate amplitudes of 8 frequencies encoding symbols. I don’t need to run full FFT for this, so I used Goertzel’s algorithm.
void goertzel(uint8_t *samples, float *spectrum) {
  float v_0, v_1, v_2;
  float re, im, amp;
  for (uint8_t k = 0; k < IX_LEN; k++) {
    float c = pgm_read_float(&(cos_t[k]));
    float s = pgm_read_float(&(sin_t[k]));
    float a = 2. * c;
    v_0 = v_1 = v_2 = 0;
    for (uint16_t i = 0; i < N; i++) {
      v_0 = v_1;
      v_1 = v_2;
      v_2 = (float)(samples[i]) + a * v_1 - v_0;
    re = c * v_2 - v_1;
    im = s * v_2;
    amp = sqrt(re * re + im * im);
    spectrum[k] = amp;
Step 2: The Code
The picture above shows the example of encoding of digit 3 where maximum amplitude corresponds to frequencies 697Hz and 1477Hz.
The complete sketch looks as follows
* Connections: * [ Mic to Arduino ] * - Out -> A0 * - Vcc -> 3.3V * - Gnd -> Gnd * - Arduino: AREF -> 3.3V * [ Display to Arduino ] * - Vcc -> 5V * - Gnd -> Gnd * - DIN -> D11 * - CLK -> D13 * - CS -> D9 */ #include #include
#include
#define CS_PIN 9
#define N 256 #define IX_LEN 8 #define THRESHOLD 20
LEDMatrixDriver lmd(1, CS_PIN);
uint8_t samples[N]; volatile uint16_t samplePos = 0;
float spectrum[IX_LEN];
// Frequences [697.0, 770.0, 852.0, 941.0, 1209.0, 1336.0, 1477.0, 1633.0] // Calculated for 9615Hz 256 samples const float cos_t[IX_LEN] PROGMEM = { 0.8932243011955153, 0.8700869911087115, 0.8448535652497071, 0.8032075314806449, 0.6895405447370669, 0.6343932841636456, 0.5555702330196023, 0.4713967368259978 }; const float sin_t[IX_LEN] PROGMEM = { 0.44961132965460654, 0.49289819222978404, 0.5349976198870972, 0.5956993044924334, 0.7242470829514669, 0.7730104533627369, 0.8314696123025451, 0.8819212643483549 };
typedef struct { char digit; uint8_t index; } digit_t;
digit_t detected_digit;
const char table[4][4] PROGMEM = { {'1', '2', '3', 'A'}, {'4', '5', '6', 'B'}, {'7', '8', '9', 'C'}, {'*', '0', '#', 'D'} };
const uint8_t char_indexes[4][4] PROGMEM = { {1, 2, 3, 10}, {4, 5, 6, 11}, {7, 8, 9, 12}, {15, 0, 14, 13} };
byte font[16][8] = { {0x00,0x38,0x44,0x4c,0x54,0x64,0x44,0x38}, // 0 {0x04,0x0c,0x14,0x24,0x04,0x04,0x04,0x04}, // 1 {0x00,0x30,0x48,0x04,0x04,0x38,0x40,0x7c}, // 2 {0x00,0x38,0x04,0x04,0x18,0x04,0x44,0x38}, // 3 {0x00,0x04,0x0c,0x14,0x24,0x7e,0x04,0x04}, // 4 {0x00,0x7c,0x40,0x40,0x78,0x04,0x04,0x38}, // 5 {0x00,0x38,0x40,0x40,0x78,0x44,0x44,0x38}, // 6 {0x00,0x7c,0x04,0x04,0x08,0x08,0x10,0x10}, // 7 {0x00,0x3c,0x44,0x44,0x38,0x44,0x44,0x78}, // 8 {0x00,0x38,0x44,0x44,0x3c,0x04,0x04,0x78}, // 9 {0x00,0x1c,0x22,0x42,0x42,0x7e,0x42,0x42}, // A {0x00,0x78,0x44,0x44,0x78,0x44,0x44,0x7c}, // B {0x00,0x3c,0x44,0x40,0x40,0x40,0x44,0x7c}, // C {0x00,0x7c,0x42,0x42,0x42,0x42,0x44,0x78}, // D {0x00,0x0a,0x7f,0x14,0x28,0xfe,0x50,0x00}, // # {0x00,0x10,0x54,0x38,0x10,0x38,0x54,0x10} // * };
void initADC() { // Init ADC; f = ( 16MHz/prescaler ) / 13 cycles/conversion ADMUX = 0; // Channel sel, right-adj, use AREF pin ADCSRA = _BV(ADEN) | // ADC enable _BV(ADSC) | // ADC start _BV(ADATE) | // Auto trigger _BV(ADIE) | // Interrupt enable _BV(ADPS2) | _BV(ADPS1) | _BV(ADPS0); // 128:1 / 13 = 9615 Hz ADCSRB = 0; // Free-run mode DIDR0 = _BV(0); // Turn off digital input for ADC pin TIMSK0 = 0; // Timer0 off }
void goertzel(uint8_t *samples, float *spectrum) { float v_0, v_1, v_2; float re, im, amp; for (uint8_t k = 0; k < IX_LEN; k++) { float c = pgm_read_float(&(cos_t[k])); float s = pgm_read_float(&(sin_t[k])); float a = 2. * c; v_0 = v_1 = v_2 = 0; for (uint16_t i = 0; i < N; i++) { v_0 = v_1; v_1 = v_2; v_2 = (float)(samples[i]) + a * v_1 - v_0; } re = c * v_2 - v_1; im = s * v_2; amp = sqrt(re * re + im * im); spectrum[k] = amp; } }
float avg(float *a, uint16_t len) { float result = .0; for (uint16_t i = 0; i < len; i++) { result += a[i]; } return result / len; }
int8_t get_single_index_above_threshold(float *a, uint16_t len, float threshold) { if (threshold < THRESHOLD) { return -1; } int8_t ix = -1; for (uint16_t i = 0; i < len; i++) { if (a[i] > threshold) { if (ix == -1) { ix = i; } else { return -1; } } } return ix; }
void detect_digit(float *spectrum) { float avg_row = avg(spectrum, 4); float avg_col = avg(&spectrum[4], 4); int8_t row = get_single_index_above_threshold(spectrum, 4, avg_row); int8_t col = get_single_index_above_threshold(&spectrum[4], 4, avg_col); if (row != -1 && col != -1 && avg_col > 200) { detected_digit.digit = pgm_read_byte(&(table[row][col])); detected_digit.index = pgm_read_byte(&(char_indexes[row][col])); } else { detected_digit.digit = 0; } }
void drawSprite(byte* sprite) { // The mask is used to get the column bit from the sprite row byte mask = B10000000; for(int iy = 0; iy < 8; iy++ ) { for(int ix = 0; ix < 8; ix++ ) { lmd.setPixel(7 - iy, ix, (bool)(sprite[iy] & mask ));
// shift the mask by one pixel to the right mask = mask >> 1; }
// reset column mask mask = B10000000; } }
void setup() { cli(); initADC(); sei();
Serial.begin(115200); lmd.setEnabled(true); lmd.setIntensity(2); lmd.clear(); lmd.display();
unsigned long z = 0;
void loop() { while(ADCSRA & _BV(ADIE)); // Wait for audio sampling to finish goertzel(samples, spectrum); detect_digit(spectrum);
if (detected_digit.digit != 0) { drawSprite(font[detected_digit.index]); lmd.display(); } if (z % 5 == 0) { for (int i = 0; i < IX_LEN; i++) { Serial.print(spectrum[i]); Serial.print("\t"); } Serial.println(); Serial.println((int)detected_digit.digit); } z++;
samplePos = 0;
ADCSRA |= _BV(ADIE); // Resume sampling interrupt }
ISR(ADC_vect) { uint16_t sample = ADC;
samples[samplePos++] = sample - 400; if(samplePos >= N) { ADCSRA &= ~_BV(ADIE); // Buffer full, interrupt off } }
Step 3: Schematics
The following connections should be made:
Mic to Arduino
Out -> A0
Vcc -> 3.3V
Gnd -> Gnd
It is important to connect AREF to 3.3V.
Display to Arduino
Vcc -> 5V
Gnd -> Gnd
DIN -> D11
CLK -> D13
CS  -> D9
Step 4: Conclusion
What could be improved here? I used N = 256 samples at rate 9615Hz which has some spectrum leakage, if N = 205 and rate is 8000Hz then the desired frequencies coincide with discretisation grid. For that ADC should be used in timer overflow mode.
    • Beauty Tips Contest
      Beauty Tips Contest
    • Classroom Science Contest
    • Sensors Contest
      Sensors Contest
    DIY Hacks and How Tos
    5 months ago
    This is really cool. I wish that my teachers had given us assignments like this when I was in school.
