Dancing Blue Flame
Introduction: Dancing Blue Flame
About: Currently working as a Science Lab Technician in an International School. Also, I’m a Professional Biology Teacher.
I did this experiment to demonstrate and study the reaction between copper chloride- HCl Solution and Aluminum foil. The mixture will begin to react vigorously and produce hydrogen gas. It was then ignited in a closed container resulting to the formation of the Blue Flame.
Reaction:
2Al(s) + 3CuCl2(aq) → 2AlCl3(aq) + 3Cu(s)
2Al(s) + 6HCl(aq) → 2AlCl3(aq) + 3H2(g)
Materials and Reagents Needed:
1. 3.5 g of Copper Chloride
2. 50 ml of 1.0 M HCl
3. Small and big conical flasks
4. Measuring cylinder
5. Gas lighter
6. Aluminum Foil
7. Weighing boat
The primary objective here is to show how reactive aluminium is. The aluminium oxide layer protects the metal beneath from further reaction with air, water or acid. But chloride ions can ligate aluminium ions at the metal–oxide interface and break down the protective layer, allowing the reaction to proceed.
This report presents the procedures for the experiment, the experiment's results, and an analysis of those results.
Step 1: Hydrochloric Acid
Measure about 50 ml of 1.0 M Hydrochloric acid
Step 2: Copper Chloride
Put 3.5 g of Copper Chloride into the flask.
Step 3: The Mixture
Pour the 50 ml of HCl into the conical flask.
Step 4: Dissolving the Copper Chloride Into the Acid
Swirl the contents well.
Step 5: Reaction Between the Solution and Metal Foil
Add the Copper chloride- Hydrochloric acid mixture to the foil in the second flask.
Step 6: Production of Hydrogen Gas
After few seconds, the mixture will begin to react vigorously and produce Hydrogen gas.
Step 7: Ignition
Hold the gas lighter and lit the opening of the flask and the gas will ignite.
Step 8: The Reaction
You can see the blue flame appears after the ignition. If you have timed it right, the flame will sink back into the flask and dance inside above the reaction with an eerie blue green color from the copper.
1 Person Made This Project!
  • Mason Jar Speed Challenge
  • Bikes Challenge
    Bikes Challenge
  • Remix Contest
    Remix Contest
3 Discussions
SHOE0007
SHOE0007
1 year ago
Hmm interesting chemistry using hydrogen and copper salts to produce a blue flame. Neat!
WeTeachThemSTEM
WeTeachThemSTEM
1 year ago
Thanks for sharing this project! What grade level of students would you do this project with?
swag_science
swag_science
Reply 1 year ago
Year 11 and 12
