Dark Detector Using BC547 Transistor
About: i am an electronics hobbyist.
In this tutorial we will make a dark detector circuit using BC547 transistor.
Teacher Notes
Step 1: Working:
when LDR will detect dark then LED start glowing automatic and when LDR will detect light LED goes off.
Step 2: Components Required:
  1. 1 x BC547 transistor
  2. 1 x LDR
  3. 1 x 330ohm resistor
  4. 1 x 100k ohm resistor
  5. 9V battery
  6. Breadboard
Step 3: Connection:
Connect the all components according to above circuit diagram.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
