Data Logger - Logging Computer Module
Ethernet data logger for HTTP based data collection from Sensor Bridges that convert I2C interfaced sensor to Ethernet sensor.
Supplies:
Sensor Bridge Digital
Power supply 24 V
Teacher Notes
Step 1: Connecting the Logging Computer Module
  1. Connect the power supply to the screw connector in the front
  2. Connect an ethernet cable from the front port to your router You should see the green indicator LED lit as well as the ethernet port LEDs showing traffic.
Step 2: Connect the Sensor Bridge
Do the same process to the Sensor Bridge.
  2. Connect an ethernet cable from the front port to your router Again, you should see the green indicator LED lit as well as the ethernet port LEDs showing traffic.
  3. Connect the T9602 sensor in place
The sensor will only be read after you send a HTTP request to the sensor. Network connections Your final connections should resemble the following architecture
Step 3: Configure the Logging Process
  1. Browse to 192.168.1.189, which is the default IP address of the Logging Computer Module. The web page can only be accessed within the network the Logging Computer Module was connected to
  2. Click on Sensors to view an empty listing
  3. Click on Add New in top toolbar
  4. Enter the sensor details
  • Sensor name: Name the sensor, for example "S1_T9602_Rh"
  • IP: Enter default Sensor Bridge IP 192.168.1.190
  • Command: "T96025D1RH" for humidity"T96025D1RH" for temperature "TEMPINT" for internal temperature (handy for checking connection)
  • Port: Enter default port 80
  • Operation: Choose the plus sign "+".
  • Operand: Enter 0.
  • Unit: Unit of the measurement; %Rh or C
Step 4:
  1. Click on Records to view an empty listing
  2. Click on Add New in top toolbar
  • Record name: Enter a name you can recognize the measurement by
  • Sample interval: Enter the desired sample interval in seconds.
  • Sensor: Pick the sensor from drop-down menu
Step 5: View Data
In records view you can:
  • View full graphs
  • Zoom into an interesting region
  • View results by hovering over the graph
  • Export data to CSV-file
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
