Designing Tower Top Base
Introduction: Designing Tower Top Base
Follow this instructable to create the tower top base.
Teacher Notes
Step 1: Circle
Our group took measurements of the sensors and incorporated the measurements into the design on OnShape. With the measurements we created a design with the following steps:
First. make a circle with a diameter of 64 mm, extrude the circle 5 mm, and then create a hole in the circle with a diameter of 30 mm. Extrude the circle 4 mm.
Step 2: Draw a Hexagon
Draw a hexagon that has the same center point as the circle. Create a point at each of the vertices (6). Then draw a line that is 8 mm from each point to the circumference of the circle.
Step 3: Creating the Edges
Next, draw new lines from the original lines to create 6 rectangular prisms. Extrude the rectangles 5 mm.
Step 4: More Edges!
Draw a line that is 4 mm from each side of the rectangular prisms. Next, find the midpoints of each of the spaces in between every rectangular prism. Then, draw a perpendicular line from the midpoints to the center of the circle. Create a point at each of these points. Then, draw a line from the 4 mm lines to the midpoints. Then draw a line from the inside of the rectangular prisms to the midpoints. Extrude all of the new spaces 4 mm.
Step 5: Extrude More
Select all of the spaces that were just created, and extrude them an additional 14 mm.
Step 6: The Tower Base Is Complete
The Tower Base is complete now.
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
    audreyobscura
    audreyobscura
    2 months ago
    Thanks for the design tips!
