Device Art Final: Turntable for Night Owls
Introduction: Device Art Final: Turntable for Night Owls
1. [Rotating a turntable] Prepare laser-cut wood pieces (2 rectangles, 2 squares, 1 circle)
Teacher Notes
Step 1:
2. Mark the center point of one rectangle panel and drill it, large enough to fit a servo motor’s circle
Step 2:
3. Attach a part of servo motor on a circle panel with a tape
Step 3:
4. Connect the circle panel right on the center of the rectangle panel.
Step 4:
5. [Pulse sensor and MP3 speaker on a breadboard] Before making a circuit, make sure to download MP3 files in micro SD card and put it in a MP3 sensor.
Step 5:
6. Make the same circuit as above for connecting a MP3 player and a pulse sensor.
Step 6:
7. Complete attaching a servo motor — a circle panel and the motor itself.
Step 7:
8. Put all the circuits within the box and enclose it with another rectangle panel.
Step 8:
9. Copy and paste the codes below into Arduino Uno.
#include
#include "SoftwareSerial.h"
SoftwareSerial mySerial(10, 11);
# define Start_Byte 0x7E
# define Version_Byte 0xFF
# define Command_Length 0x06
# define End_Byte 0xEF
# define Acknowledge 0x00 //Returns info with command 0x41 [0x01: info, 0x00: no info]
# define ACTIVATED LOW
int buttonNext = 2;
int buttonPause = 3;
int buttonPrevious = 4;
boolean isPlaying = false;
Servo servo_9;
#include
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 5, 6, 7, 8);
#define USE_ARDUINO_INTERRUPTS true // Set-up low-level interrupts for most acurate BPM math.
#include // Includes the PulseSensorPlayground Library.
// Variables
const int PulseWire = 0; // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED13 = 13; // The on-board Arduino LED, close to PIN 13.
int Threshold = 550;
PulseSensorPlayground pulseSensor;
void setup () {
Serial.begin(9600);
servo_9.attach(9);
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED13); //auto-magically blink Arduino's LED with heartbeat.
pulseSensor.setThreshold(Threshold);
// Double-check the "pulseSensor" object was created and "began" seeing a signal.
if (pulseSensor.begin()) {
Serial.println("We created a pulseSensor Object !"); //This prints one time at Arduino power-up, or on Arduino reset.
pinMode(buttonPause, INPUT);
digitalWrite(buttonPause,HIGH);
pinMode(buttonNext, INPUT);
digitalWrite(buttonNext,HIGH);
pinMode(buttonPrevious, INPUT);
digitalWrite(buttonPrevious,HIGH);
mySerial.begin (9600);
delay(1000);
//playFirst();
//isPlaying = true;
pause();
void loop () {
myStepper.setSpeed(100);
// step 1/100 of a revolution:
myStepper.step(stepsPerRevolution/
100 );
int myBPM = pulseSensor.getBeatsPerMinute(); // Calls function on our pulseSensor object that returns BPM as an "int".
//// delay(5000) ; // "myBPM" hold this BPM value now.
/if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if "a beat happened".
// Serial.println("♥ A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
// Serial.print("BPM: "); // Print phrase "BPM: "
Serial.println(myBPM); // Print the value inside of myBPM.
if(myBPM<120){
isPlaying = true;
play();
servo_9.write(180);
else if(myBPM>170){
// pause();
playNext();
// servo_9.write(0);
// if(myBPM>140){
// playNext();
// if (digitalRead(buttonPause) == ACTIVATED)
// if(isPlaying)
// pause();
// isPlaying = false;
// }else
// isPlaying = true;
// play();
/ if (digitalRead(buttonNext) == ACTIVATED)
// if(isPlaying)
// playNext();
/ if (digitalRead(buttonPrevious) == ACTIVATED)
// if(isPlaying)
// playPrevious();
void playFirst()
execute_CMD(0x3F, 0, 0);
delay(500);
setVolume(20);
delay(500);
execute_CMD(0x11,0,1);
delay(500);
void pause()
execute_CMD(0x0E,0,0);
delay(500);
void play()
execute_CMD(0x0D,0,1);
delay(500);
void playNext()
execute_CMD(0x01,0,1);
delay(500);
void playPrevious()
execute_CMD(0x02,0,1);
delay(500);
void setVolume(int volume)
execute_CMD(0x06, 0, volume); // Set the volume (0x00~0x30)
delay(2000);
void execute_CMD(byte CMD, byte Par1, byte Par2)
// Excecute the command and parameters
// Calculate the checksum (2 bytes)
word checksum = -(Version_Byte + Command_Length + CMD + Acknowledge + Par1 + Par2);
// Build the command line
byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length, CMD, Acknowledge,
Par1, Par2, highByte(checksum), lowByte(checksum), End_Byte};
//Send the command line to the module
for (byte k=0; k<10; k++)
mySerial.write( Command_line[k]);
Step 9:
10. It starts playing music and rotating a turntable depending on your heart rate :)
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
