Digital Water Level Meter With Arduino
Introduction: Digital Water Level Meter With Arduino
this tutorial shows you how to make a digital water level meter with arduino and color display
Teacher Notes
Step 1: Parts
*Any arduino board
*ili9341 tft display
*5 x 2.2k resistors ,5 x 3.3k resistors
*ultrasonic sensor
Step 2: Connection
Connect display to arduino as above.
resisters are used to convert 5v logic to 3.3. because ili9341 is only working with 3.3v signals.
otherwise whole screen will be filled with white.
*ultra sonic
Trig pin > Arduino pin 5
Echo pin > Arduino pin 6
Step 3: Code
upload this code - and change above mention lines if necessary
code file download
or copy this
#include // include Adafruit graphics library
#include // include Adafruit ILI9341 TFT library
const int trigPin = 5; const int echoPin = 6; // defines variables long duration; int distance; int presntage=0; #define TFT_CS 8 // TFT CS pin is connected to arduino pin 8 #define TFT_RST 9 // TFT RST pin is connected to arduino pin 9 #define TFT_DC 10 // TFT DC pin is connected to arduino pin 10 // initialize ILI9341 TFT library Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
int home; void setup() {
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output pinMode(echoPin, INPUT); Serial.begin(9600); Serial.println("ILI9341 Test!"); tft.begin(); // read diagnostics (optional but can help debug problems) uint8_t x = tft.readcommand8(ILI9341_RDMODE); Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDMADCTL); Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDPIXFMT); Serial.print("Pixel Format: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDIMGFMT); Serial.print("Image Format: 0x"); Serial.println(x, HEX); x = tft.readcommand8(ILI9341_RDSELFDIAG); Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
pinMode(2,INPUT); Serial.println(F("Done!"));
int home=0; } void loop(void) {
testText();
delay(4000); waterlevel(); delay(4000);
} void testFillScreen() { unsigned long start = micros(); tft.fillScreen(ILI9341_BLACK); tft.fillScreen(ILI9341_RED); tft.fillScreen(ILI9341_GREEN); tft.fillScreen(ILI9341_BLUE); tft.fillScreen(ILI9341_BLACK); }
void waterlevel() { tft.fillScreen(ILI9341_BLACK);
tft.drawRect(18,18, 84, 284,ILI9341_GREEN);
while(true) { digitalWrite(trigPin, LOW); delayMicroseconds(2); // Sets the trigPin on HIGH state for 10 micro seconds digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW); // Reads the echoPin, returns the sound wave travel time in microseconds duration = pulseIn(echoPin, HIGH); // Calculating the distance distance= duration*0.034/2; // Prints the distance on the Serial Monitor Serial.println(distance);
if(distance<6) {distance=0;} distance=distance-5; if(distance<0) {distance=0;}
if(distance>130) //put here height of your water tank. {distance=130; //put the above value if change, here also }
presntage=distance*100/130; //replace 130 with your water tank height. presntage=100-presntage;
tft.setCursor(130, 130); tft.fillRect(120,120, 120, 50,ILI9341_BLACK); tft.fillRect(20,20, 80, 280,ILI9341_BLACK); tft.setTextColor(ILI9341_GREEN); tft.setTextSize(4); if(presntage!=100){ tft.print(presntage);tft.print(" %"); } else { tft.print(presntage); } if(presntage<10) { tft.fillRect(20,20+(100-presntage)*2.8, 80, presntage*2.8,ILI9341_RED); } else if(presntage<30) { tft.fillRect(20,20+(100-presntage)*2.8, 80, presntage*2.8,ILI9341_YELLOW); } else if(presntage<80) { tft.fillRect(20,20+(100-presntage)*2.8, 80, presntage*2.8,ILI9341_BLUE); } else { tft.fillRect(20,20+(100-presntage)*2.8, 80, presntage*2.8,ILI9341_GREEN); }
delay(1000); }
} void testText() { tft.fillScreen(ILI9341_BLACK); tft.setCursor(20, 40); tft.setTextColor(ILI9341_WHITE); tft.setTextSize(5); tft.println("Welcome");
tft.setCursor(30, 140); tft.setTextColor(ILI9341_RED); tft.setTextSize(2); tft.println("Press Buttons");
tft.setCursor(40, 160); tft.setTextColor(ILI9341_GREEN); tft.setTextSize(2); tft.println("To Navigate");
tft.fillRect(0,290, 100, 30,ILI9341_YELLOW);
tft.setCursor(10, 300); tft.setTextColor(ILI9341_BLUE); tft.setTextSize(2); tft.println("W.Level"); tft.fillRect(140,290, 100, 30,ILI9341_BLUE); tft.setCursor(150, 300); tft.setTextColor(ILI9341_BLACK); tft.setTextSize(2); tft.println(" Info");
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    5 Discussions
    tytower
    tytower
    5 weeks ago
    Put the ".ino " code file in please
    tytower
    tytower
    Reply 4 weeks ago
    The idea is to add the file here not send us off to unrecognised web sites where what we get could have any sort of viruses attached . They at least vet them here. Just click add file. hanks anyway Ill try it.
    Tirancm
    Tirancm
    Reply 3 days ago
    its a direct link from trusted website.no adds or viruses
    tytower
    tytower
    Reply 10 days ago
    Thanks for doing that . You want to edit it into your instructable
