Distance Measuring Device Without LCD or LED Display
Introduction: Distance Measuring Device Without LCD or LED Display
About: I work as an engineer , researcher, and student . I wanted to be an astrophysicist in the future. I like to make robots, rockets, and amazing gadgets.
I had made a distance measuring device without an LED or LCD display.
You can also make it by doing the following steps.
Teacher Notes
Step 1: Gathering Materials
We need only some material to make it and it will cost only about $10 to $15.
And the materials are as follow:-
1.Arduino Uno with connecting Cable
2.Ultrasonic Sensor
3.Jumper Wires (male to female)
4.PC or Laptop
Step 2: Making the Circuit
For making the circuit we need to do the following connections correctly:-
1. Connect the VCC pin of the sensor 5v+ to the Arduino power pin and GND to GND.
2. Connect the Echo pin to digital pin 10. And Trig to digital pin 9.
Step 3: Uploading the Code
Connect the Arduino cable to Arduino and then to Your PC or Laptop.
Copy the code given below and paste in Arduino software and upload it to Arduino.
// defines pins numbers
const int trigPin = 9;
const int echoPin = 10;
// defines variables
long duration;
int distance;
void setup() {
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
Serial.begin(9600); // Starts the serial communication
void loop() {
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
Step 4: Using the Device
For using the device click on the serial monitor and you will see that the device is showing exactly the correct distance. You can find the serial monitor on the corner side of the window with the icon like a magnifying glass.
WRITTEN BY:-
SCIENTIST ANSH MISHRA
Be the First to Share
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
