Distance Measuring Watch
Introduction: Distance Measuring Watch
About: I am a student. I love Arduino.
In this project, I have compressed and mounted the Arduino distance measuring system on to a watch. The project is cool, simple as well as useful. The distance measuring system is based on simple physics of distance, velocity, and time.
Supplies:
You need the following supplies:-
  1. Arduino Nano (or Pro Mini)
  2. I2c OLED 128 X 64
  3. Ultrasonic Sensor ( HC-SR04)
  4. A 9V battery and Clip
  5. An old Wrist Watch
  6. Mini Breadboard (170 pts)
  7. Jumpers
  8. Double-sided Tape
Teacher Notes
Step 1: Assembling and Schematics
Assemble the components as follows
OLED - Arduino
GND - GND
VCC - 5V
SDA - A4
SCL - A5
HC-SR04 - Arduino
GND - GND
VCC - 5V
TRIG - D12
ECHO - D11
9V BATTERY - Arduino
+ve - VIN
-ve - GND
Step 2: Uploading the Code
Upload the project code onto your Arduino board. Check your correct port and board type. Download the required Adafruit SSD1306 and Adafruit GFX libraries.
Step 3: Testing the Circuit
Connect the battery to the circuit and test if it works properly.
Step 4: (Final Step) Mounting on Watch
Stick the breadboard to the battery using double-sided tape. Now stick the other part of the battery to the watch using another double-sided tape.
Wearables Contest
Wearables Contest
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
