Diy Enameling Trivet
Introduction: Diy Enameling Trivet
About: I'm a social-worker, working with 12 - 23 year-olds. I used to be a printer. In 2018 I opened a small makerspace (www.imdib.nl) in my house, where I have lasercutters, 3d-printers, Arduino's, Mindstorms and ...
So I've bought a kiln...
I couldn't find a shop where I could buy a couple of cheap trivets in my country, but it didn't seem hard to make them myself and I always wanted to try welding.
So here we go.
Teacher Notes
Step 1: You Will Need
Materials:
  • thin sheet steel
  • paper
Tools:
  • scissors
  • steel cutter
  • some way to bend steel
  • welder
  • steel clamps
  • ruler
  • square
  • pencil
Step 2: Design the Trivet
The easiest design seems to be 3 triangles welded together.
To test out the design, I first cut them from a piece of paper. This way I tested both the size and the design.
I ended up making the trivets 5 cm (2 inch) high.
Step 3: Cut the Squares
  • Measure squares of 5 x 5 cm on the steel.
  • Cut the squares with any type of metal shear.
Step 4: Make the Triangles
  • Cut the squares from corner to corner in half to make triangles.
  • Bend one of the sharp corners from each triangle 60 degrees.
  • 3 triangles put together wil form the trivet.
Step 5: Welding
  • Clamp the 3 triangles together.
  • (spot)weld the triangles together.
Make sure that the middle is a little bit raised, so the trivet wil stand on it's 3 corners.
Step 6: Finished
  • Put your workpiece on the trivet and put it in the kiln.
  • The first time the trivet will probably scale.
To make 5 trivets took me less than 5,- euro and not even one hour from idea till finished trivets.
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    2 Discussions
    tytower
    tytower
    1 year ago
    Welding current up too high ,wire feed too low.
    kenyer
    kenyer
    Reply 1 year ago
    I'm sure that you are right. They are holding up great in the kiln, so it was good enough :)
