DockerPi Series IoT Node(A) Board for Raspberry Pi 4B
About: I am a linux fan, a maker, a boy who like make thing and have fun with my friends.
Descriptions:
IoT Node(A) is one of Docker Pi series module.
IOT Node(A) = GPS/BDS + GSM + Lora.
I2C directly controls Lora, sends and receives data, controls the GSM/GPS/BDS module through SC16IS752, the mainboard only needs I2C support.
Support Raspberry Pi and other similar products.
Features:
· Docker Pi Series
· Programmable
· Control directly (without programming)
· Extend the GPIO Pins
· GPS/BDS Support
· GSM Support
· Lora Support
· Can Stack with other Stack board
· Independent of the mainboard hardware (require I2C support)
Official Compatibility Test
Not only support the following development boards, other development boards can be compatible if they have I2C peripherals. (Note: some software changes may be required)
Raspberry Pi series (4B/3B+/3B/2B)
Supplies:
1 x Raspberry Pi 4B /3B+/3B board
1 x DockerPi IoT Node(A) Hat board
1 x 5V@3A Power supply
1 x 16GB class 10 TF card (32GB will be good)
Teacher Notes
Step 1: Specifications
GPRS section:
· 1. Low power consumption, standby sleep current <1mA
· 2. Support GSM/GPRS four frequency bands, including 850, 900, 1800, 1900MHZ;
· 3. GPRS Class 10;
· 4. Support GPRS data service, maximum data rate, download 85.6Kbps, upload 42.8Kbps;
· 5. Support standard GSM07.07, 07.05 AT commands, and access the serial port through I2C interface conversion.
· 6. AT commands support standard AT and TCP/IP command ports
GPS section:
· 1. Support BDS/GPS joint positioning
· 2. Support A-GPS, A-BDS
· 3. Support standard SIM card
LORA section:
· 1. Transmission distance:500 Meters (RF parameters: 0x50 @ China City)
· 2. Support FSK, GFSK, MSK, GMSK, LoRaTM and OOK modulation methods
· 3. Ultra-high receiver sensitivity as low as -141 dBm
· 4. Support preamble detection
· 5. Packet engine with CRC, up to 256 bytes
· 6. LORA transceiver indicator
· 7. Easy TX/RX by Docker Pi
Step 2: ​Package Includes
Package Includes
· 1 x IoT Node(A) Board
· 1 x Instructions
· 4 x M2.5*12 + 6 Copper stick
· 4 x M2.5*6 Nut
· 4 x M2.5*6 Half-round head screw
· 1 x 433MHz L-Shaped Tape Antenna
· 1 x 2.4GHz PCB Antenna
· 1 x GPS/BDS High Gain GPS Built-in Ceramic Active Antenna
Step 3: ​Technical Details:
A9G Module
· A9G module offers two serial port.
· Use I2C <=> UART bridge for communication.
Step 4: Register Map
here is the register map and the description of the register.
0x01 - 0x10 Write Only.
0x11 - 0x20 Read Only.
It is recommended to keep the default unless you know the meaning of the LORA parameter.
L_SET(Write Only)
1. Write 1 to set parameters from 0x22 to LORA Module.
2. Write 0 not effect
· G_RESET(Write Only)
1. Write 1 to reset A9G Module
· L_RXNE(Read & Write)
1. Write 1 cause error
2. Write 0 to clear
3. Read 1 means data has been received, please get the data from the register 0x11 - 0x20.
4. Read 0 means no data available now.
· L_SET(Write Only)
1. Write 1 to send data,please fill in the data in register 0x01 - 0x10 before send.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
