Doggo Meal Prep
About: I'm Dan, hobbyist and maker of things.
Sometimes, having a dog can be time consuming. But why should boring tasks like feeding time get in the way of snuggling with them in the morning, or going on long walks?
Meal prep doesn't just have to be for humans, doggos can benefit too.
Here's a quick Instructable for dog food meal prep.
Supplies:
Dog Food
Small Tupperware
Kitchen Scales
(+ A doggo to feed)
Teacher Notes
Step 1: Gather Your Equipment
The ideal tub is sealed, and as small as possible. Minimal wasted space means more space in travel bags for doggy toys and miniature tennis balls.
The ideal food is dry and tasty (to the dog - optional to be tasty to humans...). Dose size should be on the side of the bag, unless the vet specifies otherwise.
The ideal scales show the weight. Obviously.
Step 2: Weigh Out the Food
Remember to tare/zero the scales once the empty tub is on them. Pour the food, make it as accurate as possible.
If you have a well-sized scoop/cup/etc., you may not need to weigh it, just fill to the required level.
Step 3: Repeat As Necessary
Economies of scale says the more you make the higher the efficiency. So basically, do as many as you can at once. I only have 5 tubs, and one is for doggo treats.
Step 4: Feed the Doggo!
No point meal prepping if you don't feed the doggo.
Whenever you're next running late or are away with the dog for the weekend, pop out the prepped tub and let doggo go mad on it.
Meal Prep Challenge
Meal Prep Challenge
Be the First to Share
    • STEM Contest
      STEM Contest
    • Cookies Contest
      Cookies Contest
    • Reuse Contest
      Reuse Contest
    2 Discussions
    Organikmechanic
    4 weeks ago
    Great character shot of your dog - you should get a prize for that alone! Best Wishes and Good Luck, Andy
    audreyobscura
    5 weeks ago
    This is a good idea! I may do this the next time I have to go out of town and have a doggo sitter :D
