Don't Cut Me! Plant
How to make a Don't cut me! Plant.
Supplies:
Plant/Flower
Robot Arm
Wires
Alligator Clips
MaKey CaKey
Plywood
Glue Gun
Saw
Scissors
Drill
Cable Zip Ties
Supplies:
Supplies:
Plant/Flower
Robot Arm
Wires
Alligator Clips
MaKey CaKey
Plywood
Glue Gun
Saw
Scissors
Drill
Cable Zip Ties
Teacher Notes
Step 1: Make a Box Out of Plywood That Will Fit Your Plant and Robot Arm
Just remember to have one side of the box open!
Step 2: Drill a Hole in the Box for the Wire to Connect to the Plant
Step 3: Stab the Plant With the Wire
Step 4:
Step 5: Use the Alligator Clip on the Wire
Step 6: Then Put Your Robot Arm on the Other Plywood Box
Step 7: Fasten the Scissors to the Robot Arm With Cable Zip Ties
Step 8: Connect the Wire to the Scissors
Step 9: I Recommend to Fasten the Robot Arm and the Wire Just in Case
Step 10: Then Do the Same With This Wire and an Extra Alligator Clip
Step 11: Then Connect the Alligator Clips to the MaKey MaKey and Pick a Sound!
When the scissors connect to the plant the sound will come. I recommend screaming sounds!
Step 12:
Be the First to Share
    • Made with Math Contest
    • Cardboard Speed Challenge
    • Multi-Discipline Contest
    audreyobscura
    19 days ago
    This is so silly, I love it!
