Introduction: Command Line Commands
I have decided to change the title of this 'ible (if you can call it that). Instead of just having batch files, I'm going to have all different sorts of things, like VBScript and C# (if I can debug them, that is).
There is no difference between a batch file and a C# executable (in terms of invoking it), however, VBScripts need to be run differently, which I will get to.
So, here they are.
Step 1: Index
Instructions
NCOL ~ Have different coloured text and background colours. (.bat)
EMPTY ~ Checks if a file (or multiple files) are empty. (.bat, .vbs)
PROP ~ Displays the attributes of a file. (.bat, .vbs)
TALK ~ Makes your computer speak text. (.bat, .vbs)
HIDE ~ Starts a batch file (haven't tested it on anything else, but it might work) completely hidden. (.bat, .vbs)
ALARM ~ Emits a 'beep' after a timeout and displays a message (optional). (.bat, .vbs)
LEN ~ Returns the length of a phrase. (.vbs)
Step 2: How to Install
Firstly, select a command you would like, and either copy and paste the code, or download the .zip file. If it is a VBScript, save it as whatever.vbs. If it is a batch file, save it as whatever.bat. If you had to download something, extract the .zip file and you're done.
To make them able to run on your batch files, you have many options:
1. Put them in the directory of your batch file (if you change the directory it won't work).
2. Put them into a folder, and add it to your PATH variable via the SETX command.
3. Put them into a pre-existing directory that is part of the PATH variable (such as C:\Windows\System32\).
4. Etc...
To activate a VBScript, you need to use the CSCRIPT command.
Here's the syntax:
CSCRIPT file.vbs "arguments"
NOTE:
When you do that, it spams you a little with the Windows logo, so put:
CSCRIPT /nologo file.vbs "arguments"
instead, as it will stop it from doing that.
NOTE:
I've made the VBScripts quit if you start them wrong.
Step 3: NCOL ~ Different Coloured Text
Remember: NCOL cannot yet process special characters. Such as ~!@#$%^&*()_+ and a lot more.
For a breif description, once installed, type in:
NCOL /?
in the command prompt
@echo off
setlocal
if "%~1"=="/?" (
echo.
echo ncol ["Text"] [Colour]
echo.
echo "Text" - The text you want displayed in another colour.
echo Remember that spaces cannot be added if you don't put the text in
echo quotation marks (""^).
echo.
echo Colour - The hexadecimal colour code that you want the text to be changed into.
echo For more information of colour codes, see "color /?"
echo.
exit /b
for /f "delims=#" %%i in ('"prompt #$H# &for %%b in (1) do rem"') do set "bs=%%i"
<nul >"%~1.@" set /p "=.%bs%%bs%%bs%%bs%"
findstr /p /a:%2 . "*.@"
endlocal
del "*.@"
@echo on
@exit /b
Usage:
NCOL "Text" colour code
Where text is the output of the function, and colour is the hexadecimal colour code that the file will convert "text" into.
Example:
NCOL "Hello World" 10 Would output:
Hello World
Step 4: EMPTY ~ Checks If a File Contains No Data
The EMPTY command determines whether or not a file is empty, and if it isn't, so long as the Q switch isn't enabled, it tells you the size of the file.
Now in VBScript!
--BATCH--
@echo off
setlocal
if "%1"=="/?" (
echo.
echo EMPTY "filepath"
echo.
endlocal
exit /b
call :isEmpty %1
if errorlevel 2 (
echo The file doesn't exist.
) else if errorlevel 1 (
echo The file is not empty.
) else (
echo The file is empty.
echo.
goto :eof
:isEmpty
if not exist "%~1" exit /b 2
set "size=%~z1"
echo The size of the file is %size%
if %size% gtr 0 (exit /b 1) else exit /b 0
--VBSCRIPT--
' Test if it has been run correctly.
if wscript.fullname = "C:\Windows\System32\wscript.exe" then
wscript.echo "Please use ""cscript /nologo alarm.vbs [parameters]"" to invoke this script."
wscript.quit
end if
set fso = createobject("Scripting.FileSystemObject") ' Get access to files on the computer.
' Check for missing arguments and non-existing files.
if wscript.arguments.count = 0 then
usage(1)
else if fso.fileexists(wscript.arguments.item(0)) then
usage(2)
else if wscript.arguments.item(0) = "/?" then
usage(0)
end if
end if
end if
' Determining file size, and whether it's empty.
sfile = wscript.arguments.item(0)
set ofile = fso.getfile(sfile)
size = ofile.size
if size = 0 then
wscript.echo "The file is empty."
else
wscript.echo "The file is not empty."
end if
wscript.echo "The size of the file is " & size
function usage(errorlevel)
wscript.echo
wscript.echo "Determine if a file is empty, and display the size (in bytes)."
wscript.echo
wscript.echo "USAGE:"
wscript.echo "cscript /nologo empty.vbs ""file path"""
wscript.echo
wscript.quit(errorlevel)
end function
Once again, you use it like any other command.
Type in EMPTY /? to get the help message.
Step 5: PROP ~ Attribute Checker
This function checks what attributes the file has.
Now in VBScript.
@echo off
setlocal enabledelayedexpansion
if "%1"=="/?" (
echo.
echo PROP "filepath"
echo.
echo Attributes:
echo A - Archived
echo R - Read Only
echo H - Hidden
echo S - System
echo C - Compressed
echo T - Temporary
echo.
exit /b
if not exist %1 (
echo No file of that name exists.
echo.
exit /b
set "attribs=%~a1"
set attrib1=!attribs:~0,1!
set attrib2=!attribs:~1,1!
set attrib3=!attribs:~2,1!
set attrib4=!attribs:~3,1!
set attrib5=!attribs:~4,1!
set attrib6=!attribs:~5,1!
set attrib7=!attribs:~6,1!
set attrib8=!attribs:~7,1!
set attrib9=!attribs:~8,1!
if %attrib1% equ d echo Directory
if %attrib2% equ r echo Read Only
if %attrib3% equ a echo Archived
if %attrib4% equ h echo Hidden
if %attrib5% equ s echo System File
if %attrib6% equ c echo Compressed File
if %attrib7% equ o echo Offline File
if %attrib8% equ t echo Temporary File
if %attrib9% equ l echo Reparse point
echo.
exit /b
Run it like you would any command.
if wscript.fullname = "C:\Windows\system32\wscript.exe" then
wscript.echo "Please use ""cscript /nologo prop.vbs [parameters]"" to invoke this script."
wscript.quit
end if
set fso = createobject("scripting.filesystemobject") ' Give access to files.
' Test for invalid arguments, etc...
usage(1)
usage(0)
else if not fso.fileexists(wscript.arguments.item(0)) then
usage(2)
end if
end if
end if
' Do stuff.
set file = fso.getfile(wscript.arguments.item(0))
If file.Attributes AND 0 Then
Wscript.Echo "No attributes set."
End If
If file.Attributes AND 1 Then
Wscript.Echo "Read-only."
End If
If file.Attributes AND 2 Then
Wscript.Echo "Hidden file."
End If
If file.Attributes AND 4 Then
Wscript.Echo "System file."
End If
If file.Attributes AND 32 Then
Wscript.Echo "Archive bit set."
End If
If file.Attributes AND 64 Then
Wscript.Echo "Link or shortcut."
End If
If file.Attributes AND 2048 Then
Wscript.Echo "Compressed file."
End If
wscript.echo "Return file attributes."
wscript.echo
wscript.echo "PROP ""file"""
wscript.echo
end function
Step 6: TALK ~ the Computer Now Speaks
The TALK command is useful for things like games, menus and generally kicking ass.
Now in VBScript!
--EDIT--
The /f switch has been added to enable the contents of a file to be read.
--BATCH--
@echo off & setlocal enabledelayedexpansion
if "%~1"=="/?" (
echo.
echo TALK "Text" [Parameters]
echo.
echo Text - The phrase you want to be spoken.
echo.
echo [Parameters]:
echo /f - Read the contents of a file. "Text" changes to the file path.
echo.
endlocal
exit /b
set text=
if [%2]==[/f] (
if exist "%~1" (
for /f "usebackq delims=" %%i in (%1) do set text=!text! %%i
) else (
endlocal
exit /B
if [%2]==[] set text=%~1
echo set speech = Wscript.CreateObject^("SAPI.spVoice"^) > "talk.vbs"
echo speech.speak "%text%" >> "talk.vbs"
cscript //NoLogo //B talk.vbs
del Talk.vbs
endlocal
exit /b
--VBS--
wscript.quit
end if
set speech = wscript.createobject("sapi.spvoice") ' Get the speech object.
' Test for invalid parameters, etc...
usage(1) ' If no parameters are given, return errorlevel of 1.
usage(0)
end if
end if
' Decide where to send you.
if wscript.arguments.count = 2 then
if wscript.arguments.item(1) = "/f" then
talk_file(wscript.arguments.item(0))
else
usage(3) ' If second parameter is not "/f", return errorlevel of 3.
end if
else
talk(wscript.arguments.item(0))
end if
' Talking normally.
function talk(text)
speech.speak text
wscript.quit
end function
' Speaking the contents of a file.
function talk_file(file)
set fso = wscript.createobject("scripting.filesystemobject")
if not fso.fileexists(file) then
usage(2) ' If file doesn't exist, return errorlevel of 2.
end if
set ofile = fso.opentextfile(file,1)
speech.speak ofile.readall()
wscript.quit
end function
' Usage:
wscript.echo
wscript.echo "TALK ""Text"" [Parameters]"
wscript.echo
wscript.echo "Text - The phrase you want to be spoken."
wscript.echo
wscript.echo "[Parameters]:"
wscript.echo " /f - Read the contents of a file. ""Text"" changes to the file path."
wscript.echo
end function
Once again, use this like you would a real command, because it is.
Step 7: HIDE
I'm sick of explaining the syntax of my commands, just type in hide /? and you'll get it.
One new thing I should mention, this creates a file in your AppData\Roaming file called Batch. You probably shouldn't touch that, thanks.
Now in VBScript!
--BATCH--
@setlocal enabledelayedexpansion
@echo off
if not exist %appdata%\Batch md Batch
cd %appdata%\batch
if not exist hide.vbs echo CreateObject^("Wscript.Shell"^).Run """" ^& WScript.Arguments^(0^) ^& """", 0, False> "hide.vbs"
if "%~1" equ "" goto usage
if "%~1" equ "/?" (
echo.
echo Starts a batch file hidden.
echo.
echo HIDE "file_path" "file_path"
echo.
echo Where "file_path" is the path to the file you want run hidden ^(wildcards are not accepted^).
echo.
endlocal
exit /b 1
set file=%~1
if not exist %file% (
echo.
echo File '%file%' not found.
echo.
endlocal
exit /b 2
wscript.exe "hide.vbs" "%file%" || endlocal && exit /b 3
shift
if "%~1" neq "" goto hide
endlocal
exit /b 0
--VBS--
on error resume next
wscript.quit
end if
set fso = createobject("scripting.filesystemobject") ' Gives access to files.
' Error handling:
usage(1)
usage(0)
usage(2)
end if
end if
end if
' Inner workings:
set shell = createobject("wscript.shell")
for i = 0 to wscript.arguments.count
if not isempty(wscript.arguments.item(i)) then
shell.run """" & wscript.arguments.item(i) & """",0,false
else
wscript.quit
end if
next
' Usage:
wscript.echo
wscript.echo "Starts a batch file hidden."
wscript.echo
wscript.echo "HIDE ""file_path"" ""file_path"""
wscript.echo
wscript.echo "Where ""file_path"" is the path to the file you want run hidden (wildcards are not accepted)."
wscript.echo
end function
Step 8: ALARM
Now in 2 languages:
--BATCH--
@setlocal
@echo off
if "%1" equ "/?" goto usage
if "%1" equ "" (
echo.
echo ALARM:
echo Pauses execution and emits a tone when done.
echo.
echo USAGE:
echo ALARM time message
echo.
echo time - time in seconds to wait ^(up to 99999^).
echo message - Specifies message to be displayed ^(optional^).
echo.
endlocal
exit /b
if "%~2" neq "" echo %~2 & echo.
>nul timeout %1 /NOBREAK
>tmp echo
type tmp
del tmp
endlocal
exit /b
--VBS--
wscript.quit
end if
' Tests for bad arguments, no arguments, etc...
usage(1)
else if not isnumeric(wscript.arguments.item(0)) then
usage(2)
else if wscript.arguments.item(0) then
usage(0)
end if
' Actual Stuff
wscript.echo wscript.arguments.item(1) ' Echo message.
wscript.sleep wscript.arguments.item(0) * 1000 ' Sleep script.
wscript.echo chr(007) ' Emitt beep.
' Usage:
wscript.echo
wscript.echo "ALARM:"
wscript.echo "Pauses execution and emits a tone when done."
wscript.echo
wscript.echo "ALARM time message"
wscript.echo
wscript.echo "time - time in seconds to wait (up to 99999)."
wscript.echo "message - Specifies message to be displayed (optional)."
wscript.echo
end function
Step 9: LEN
This one is in VBScript because there's already one for batch made. See the bottom for more information.
This function returns the length of a variable, phrase or anything like that. Note, without the usage and error handling, this would be a one-liner.
LEN.vbs:
wscript.quit
end if
usage
wscript.quit(1)
else
wscript.echo len(wscript.arguments.item(0))
end if
sub usage
wscript.echo
wscript.echo "Returns the length of a string."
wscript.echo "LEN 'string'"
wscript.echo
end sub
To capture the output into a variable, use this snippet:
for /f %%i in ('cscript /nologo LEN.vbs string') do set stringLength=%%i
For a batch version, see dostips.
Step 10: More
More will be coming soon!
I just need to figure out what to do next.
If you want anything, or see something that could be improved, feel free to leave a comment!
