Dot Light Pattern
362
10
Introduction: Dot Light Pattern
I started with the idea of "Can I control light with my own hands and express my own will?"
It is a 'Dot Light Pattern' that allows you to create your own colors by yourself, design your own patterns with those colors, and experience various animation effects.
Teacher Notes
Step 1: Materials
  1. Arduino UNO x 13
  2. WS2901 or WS2811 pixel LED strip (130 LEDS)
  3. Button switch x 1
  4. Snap switch x 65
  5. Potentionmeter x 65
  6. Rainbow cable
  7. Power suffly SMPS
  8. Conductor cable
  9. Acrylic transparent round bar (30mm diameter)
  10. Black color Acrylic board (5T) (500mm*790mm) x 2, (500mm*35mm) x 2, (790mm*35mm) x 2
Step 2: Construction Plan
Step 3: Hardware : Circuit Design
  1. Cut the acrylic plate like the above structure. (see step2)
  2. One piece of neo-pixel LED is put on the top and bottom of the potentionmeter hole, and a total of 65 pairs of neo-pixel LEDs are attached.
  3. A pair of neo-pixel LEDs are wired together to form a single Arduino pin.
  4. Fit 65 potentionmeters to the potentionmeter holes. (Put it on the opposite side of a neo-pixelated surface.)
  5. Attach 65 snap switches to match the switch holes.
  6. A total of thirteen Arduino UNOs are attached to each of the thirteen zones in order to tie five pieces of 65 pieces of hardware into one Arduino UNO.
  7. As shown in the attached photo, Connect the potentionmeters, snap switches and neo-pixel LEDs to the pins of the Arduino UNO by wire. (see step2)
  8. GND and 5V pins of several Arduino UNOs are collected to cable wires, then connected to external power. (see step2)
  9. Remove the dust by Air pressure.
Step 4: Hardware : Acrylic Cutting
  1. Cut the acrylic rod to a length of 50mm.
  2. One side of the acrylic rod is drilled to the size and depth to match the controller part of the potentionmeter.
  3. The acrylic rod is trimmed slightly wider than the hole for a clearance that can fit well into the potentionmeter.
  4. The other side gives a little sandpaper so that the light can be transmitted neatly.
Step 5: Arduino Programming Code
https://www.kasperkamperman.com/blog/arduino/ardui...
'hsb to rgb' code를 참고한 사이트
#include <Adafruit_NeoPixel.h>
//'adafruit_neopixel'헤더파일라는 외부 라이브러리를 포함
//네오픽셀 연결 핀번호 선언 #define PIN1 2 #define PIN2 3 #define PIN3 4 #define PIN4 5 #define PIN5 6
#define NUMPIXELS 2 //네오픽셀 LED 갯수 #define NUM_LIGHTS 5 //작동 모듈갯수(네오픽셀 오브젝트 갯수)
//네오픽셀 오브젝트 Array 선언 Adafruit_NeoPixel pixels[] = { Adafruit_NeoPixel(NUMPIXELS, PIN1, NEO_GRB + NEO_KHZ800), Adafruit_NeoPixel(NUMPIXELS, PIN2, NEO_GRB + NEO_KHZ800), Adafruit_NeoPixel(NUMPIXELS, PIN3, NEO_GRB + NEO_KHZ800), Adafruit_NeoPixel(NUMPIXELS, PIN4, NEO_GRB + NEO_KHZ800), Adafruit_NeoPixel(NUMPIXELS, PIN5, NEO_GRB + NEO_KHZ800) }; ////네오픽셀을 사용하기 위해 객체 하나를 생성한다. //첫번째 인자값은 네오픽셀의 LED의 개수 //두번째 인자값은 네오픽셀이 연결된 아두이노의 핀번호 //세번째 인자값은 네오픽셀의 타입에 따라 바뀌는 flag
////////////////////////////////////////////////////////////// //////HSV 를 RGB로 변환하는 함수 getRGB()를 위한 변수와 함수 선언
const byte dim_curve[] = { 0, 1, 1, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 4, 5, 5, 5, 5, 5, 5, 5, 5, 5, 5, 6, 6, 6, 6, 6, 6, 6, 6, 7, 7, 7, 7, 7, 7, 7, 8, 8, 8, 8, 8, 8, 9, 9, 9, 9, 9, 9, 10, 10, 10, 10, 10, 11, 11, 11, 11, 11, 12, 12, 12, 12, 12, 13, 13, 13, 13, 14, 14, 14, 14, 15, 15, 15, 16, 16, 16, 16, 17, 17, 17, 18, 18, 18, 19, 19, 19, 20, 20, 20, 21, 21, 22, 22, 22, 23, 23, 24, 24, 25, 25, 25, 26, 26, 27, 27, 28, 28, 29, 29, 30, 30, 31, 32, 32, 33, 33, 34, 35, 35, 36, 36, 37, 38, 38, 39, 40, 40, 41, 42, 43, 43, 44, 45, 46, 47, 48, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 68, 69, 70, 71, 73, 74, 75, 76, 78, 79, 81, 82, 83, 85, 86, 88, 90, 91, 93, 94, 96, 98, 99, 101, 103, 105, 107, 109, 110, 112, 114, 116, 118, 121, 123, 125, 127, 129, 132, 134, 136, 139, 141, 144, 146, 149, 151, 154, 157, 159, 162, 165, 168, 171, 174, 177, 180, 183, 186, 190, 193, 196, 200, 203, 207, 211, 214, 218, 222, 226, 230, 234, 238, 242, 248, 255, }; //
void getRGB(int hue, int sat, int val, int colors[5][3], int index) { val = dim_curve[val]; sat = 255 - dim_curve[255 - sat];
//색조, 채도 및 밝기 (HSB / HSV)를 RGB로 변환 //dim_curve는 밝기값 및 채도 (반전)에서만 사용됩니다. //이것은 가장 자연스럽게 보입니다.
int r; int g; int b; int base;
if (sat == 0) { colors[index][0] = val; colors[index][1] = val; colors[index][2] = val; } else {
base = ((255 - sat) * val) >> 8;
switch (hue / 60) { case 0: r = val; g = (((val - base) * hue) / 60) + base; b = base; break;
case 1: r = (((val - base) * (60 - (hue % 60))) / 60) + base; g = val; b = base; break;
case 2: r = base; g = val; b = (((val - base) * (hue % 60)) / 60) + base; break;
case 3: r = base; g = (((val - base) * (60 - (hue % 60))) / 60) + base; b = val; break;
case 4: r = (((val - base) * (hue % 60)) / 60) + base; g = base; b = val; break;
case 5: r = val; g = base; b = (((val - base) * (60 - (hue % 60))) / 60) + base; break; }
colors[index][0] = r; colors[index][1] = g; colors[index][2] = b; }
int rgb_colors[NUM_LIGHTS][3]; //네오픽셀 오브젝트갯수마다 rgb color 선언 int hue[NUM_LIGHTS]; //네오픽셀 오브젝트갯수마다 hue 선언 int sat[NUM_LIGHTS]; //네오픽셀 오브젝트갯수마다 명도 선언 int brignt[NUM_LIGHTS]; //네오픽셀 오브젝트갯수마다 밝기 서언
//일반 변수 선언 int startsSwitch[] = {8, 9, 10, 11, 12}; // on/off 버튼 핀번호 boolean startState[] = {false, false, false, false, false}; // on/off 상태변수
const int colorPin[] = {A0, A1, A2, A3, A4}; // 가변저항 핀번호 int colorVal[] = {0, 0, 0, 0, 0}; // 가변저항 초기값
int animationButton = 7; // 애니메이션 모드변환 버튼 핀번호
///////////////////////////////////////////////// //애니메이션 모든 변환을 위한 버튼 디바운싱 변수선언 //디바운싱? 짧은 시간내 많은 이벤트가 발생하는것에 대한 문제에 대해서 지정된 시간 간격으로 함수를 호출하여 해결 int buttonState; // 입력 핀으로부터의 현재 판독값 int lastButtonState = HIGH; // 이전의 판독값은 켜진상태로 unsigned long lastDebounceTime = 0; // 출력핀이 마지막으로 전환된 시간은 0으로 unsigned long debounceDelay = 50; // 디바운싱 타임설정;출력이 깜빡이면 증가한다 int MODE = 0; //애니메이션 모드변수
int B_Interval[5]; //블링킹을 위한 각 모듈의 랜덤 속도 변수 int B_Min = 100; //블링킹 최단속도; int B_Max = 500; //블링킹 최장속도; int R_Interval = 50; //레인보우 애니메이션 속도 변수 int D_Interval = 10; //디밍 속도 변수
boolean B_state[5]; //블링킹을 위한 각 모듈의 상태변수
/////////////////////////////////////////////////////// //멀티테스킹 애니메이션을 위한 시간변수 선언
unsigned long currentMillis; //현재시간 변수 unsigned long B_previousMillis[5]; //각 모듈의 블링킹 타이머 unsigned long DR_Millis[5]; //각 모듈의 디밍 랜덤 타이머(예비) unsigned long R_previousMillis; //레인보우 타이머 unsigned long D_previousMillis; //디밍 타이머
boolean firstRainbow = true; //레인보우 색상 초기화 상태변수
int RainbowSpeed; //레인보우 변환변수 int Bright = 100; //디밍 초기값 int BrightnessFactor = 1; //디밍 증감 값 ///////////////////////////////////////////////////////////////////////////////////
void setup() {
for (int i = 0; i < NUM_LIGHTS; i++) { pixels[i].begin(); //네오픽셀 오브젝트 초기화 }
//버튼 인풋 설정 for (int i = 0; i < NUM_LIGHTS; i++) { pinMode(startsSwitch[i], INPUT_PULLUP); //on/off 버튼 인풋 설정 } pinMode(animationButton, INPUT_PULLUP); //애니메이션 버튼 인풋 설정
for (int i = 0; i < NUM_LIGHTS; i++) { B_Interval[i] = int(random(B_Min, B_Max)); //모듈별 블링킹 랜덤 속도(인터발) 변수 생성 }
Serial.begin(9600); //통신 설정 }
void loop() {
MODE = CheckAnimMode(); //모드에 애니메이션체크모드함수를 넣는다
//버튼과 가변저항을 값을 각각 읽어 변수에 지정한다. for (int i = 0; i < NUM_LIGHTS; i++) { startState[i] = !digitalRead(startsSwitch[i]); //on/off 버튼에서 읽은 값의 반대값을 startState에 넣어준다 //startState[i] = digitalRead(startsSwitch[i]); colorVal[i] = analogRead(colorPin[i]); //가변저항에서 읽은 값을 가변저항 초기값에 넣는다 }
switch (MODE) { //애니메이션함수 스위치문 case 0: on(); //on함수 실행 break; //조건문에서 빠져나가라
case 1: rainbow(); //rainbow함수 실행 break;
case 2: dimming(); // dimming함수 실행 break;
case 3: blinking(); //blinking함수 실행 break; }
for (int i = 0; i < NUM_LIGHTS; i++) { pixels[i].show(); //네오픽셀 오브젝트 배열 켜라 }
int CheckAnimMode() {
//애니메이션 선택 버튼을 읽어 모드를 결정한다. ///////////////////////////////////////////////////// currentMillis = millis(); // 시간 측정 int reading = digitalRead(animationButton); if (reading != lastButtonState) { //입력핀으로부터 이전의 버튼의 상태와 판독값 비교 lastDebounceTime = millis(); //현재 시간을 출력핀이 마지막으로 전환된 시간에 넣음 }
if ((currentMillis - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) { //입력핀으로부터 받은 현재값과 판독값과 비교 buttonState = reading; //판독값을 buttonState에 대입
if (buttonState == LOW) { //버튼상태가 꺼져있다면 MODE++; //버튼모드 1씩 증가 if (MODE > 3) { MODE = 0; firstRainbow = true; //레인보우 색상 초기화 상태 켜짐 BrightnessFactor = 1; //디밍 증감값 Bright = 15; //밝기는 15 } } } }
lastButtonState = reading; //판독값을 이전의 버튼상태에 대입 return MODE ; 함수를 종료하고 mode함수로 값을 리턴하라 }
//////////////////////////////////////////////////////////////////// //animation mode functuation
//on void on() { Serial.println("on"); //시리얼 모니터에 on을 써라 for (int i = 0; i < NUM_LIGHTS; i++) { color_set(i, colorVal[i]); //가변저항 값에 따라 컬러 셋팅 } }
//Rainbow void rainbow() { Serial.println("rain"); //시리얼 모니터에 rain을 써라 if (firstRainbow) { RainbowSpeed = 0; //레인보우 속도 초기화 firstRainbow = false; //레인보우 색상 초기화 상태 꺼짐 } if (millis() - R_previousMillis > R_Interval) { //흐른 시간값이 레인보우 인터벌 값보다 크면 R_previousMillis = currentMillis; //현재시간을 이전의 레인보우 시간에 넣어라 RainbowSpeed += 10; //레인보우 변환변수에 10을 더해라 }
for (int i = 0; i < NUM_LIGHTS; i++) { color_set(i, (colorVal[i] + RainbowSpeed) % 1023); //레인보우컬러셋팅 }
//Dimming void dimming() { Serial.println("dimm"); //시리얼모니터에 dimm을 써라 Serial.println(Bright); //시리얼모니터에 Bright를 써라 if (currentMillis - D_previousMillis > D_Interval) { //흐른 시간값이 디밍 인터벌 값보다 크면 D_previousMillis = currentMillis; //현재시간을 이전의 디밍 시간에 넣어라 Bright += BrightnessFactor; //밝기에 디밍 증감값 1씩 올려라 } if (Bright < 100 || Bright > 254) { BrightnessFactor = -1 * BrightnessFactor; } Bright = constrain(Bright, 99, 254); //변수 밝기값을 최소값99~최대값254 사이의 값으로 한정한다
for (int i = 0; i < NUM_LIGHTS; i++) { dim_color_set(i, Bright); //디밍컬러셋팅 } }
//Blinking void blinking() { Serial.println("blink"); //시리얼모니터에 blink를 써라
for (int i = 0; i < NUM_LIGHTS; i++) { if (currentMillis - B_previousMillis[i] > B_Interval[i]) { //흐른 시간값이 블링크 인터벌 값보다 크면 B_previousMillis[i] = currentMillis; //현재시간을 이전의 블링크 시간에 넣어라 B_state[i] = !B_state[i]; //각 모듈의 블링킹 상태변수의 값의 반대값을 대입하라 } } for (int i = 0; i < NUM_LIGHTS; i++) { if (B_state[i]) { //모듈의 블링킹 상태가 읽히면 color_set(i, colorVal[i]); //가변저항 값에 따라 컬러 셋팅 } else { noColor_set(i); //읽히지 않으면 컬러 셋팅 하지않음 } }
//////////////////////////////////////////////////////////////////////////////////////// //core functuation
//color set
void color_set(int index, int colorSenser) { if (startState[index]) { hue[index] = map(colorSenser, 0, 1023, 0, 359); //0~1023값을 0~359값으로 매핑한 값을 가지고 색상값으로 지정(colorSenser에) getRGB(hue[index], 255, 255, rgb_colors, index); for (int i = 0; i < NUMPIXELS; i++) { pixels[index].setPixelColor(i, pixels[index].Color(rgb_colors[index][0], rgb_colors[index][1], rgb_colors[index][2])); } //픽셀컬러 셋팅을 rgb_colors의 r,g,b으로 설정 } else noColor_set(index); //컬러셋팅 하지않음 }
//////noColor set
void noColor_set(int index) { //컬러셋팅 하지않는 함수 설정 for (int i = 0; i < NUMPIXELS; i++) { pixels[index].setPixelColor(i, pixels[index].Color(0, 0, 0)); } //픽셀컬러 세팅을 0,0,0으로 설정 }
////dimColor set
void dim_color_set(int index, int BC) { //디밍컬러셋팅 함수 설정 if (startState[index]) { hue[index] = map(colorVal[index], 0, 1023, 0, 359); //0~1023값을 0~359값으로 매핑한 값을 가지고 색상값으로 지정(colorVal에) getRGB(hue[index], 255, BC, rgb_colors, index); for (int i = 0; i < NUMPIXELS; i++) { pixels[index].setPixelColor(i, pixels[index].Color(rgb_colors[index][0], rgb_colors[index][1], rgb_colors[index][2])); } ///픽셀컬러 셋팅을 rgb_colors의 r,g,b으로 설정 } else noColor_set(index); //컬러셋팅 하지않음 }
Step 6: A Finished Look
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Arduino Contest 2020
    3 Discussions
    mindy_010
    mindy_010
    1 year ago
    Cool. I hope you show more video clip because it feels so short.
    Hokeypokey123
    Hokeypokey123
    1 year ago
    Good. :-) I wanna see that really ! :-3
