Dream Catcher Hoops
This is a dream catcher made out of steel hoops that you can make it only 10 easy steps.
Teacher Notes
Step 1: Step 1
Material You Need-
- Yarn the color of your choice
- 2 4" steel hoops
- 2 6" steel hoops
-2 10" steel hoops
Step 2: Step 2
Begin by cutting a long piece of yarn. Once cut start by hot gluing end to the steel hoop. Wrap the yarn around the hoop tightly until the entire hoop is covered by yarn. Repeat until each hoop is wrapped in yarn EXCEPT for one of the 4' hoops. If midway the yarn runs out, hot glue where you left off then hot glue another yarn strip on and continue.
Step 3: Step 3
With both of the small 4" hoops, connect them then tie them together with yarn then continue to finish wrapping the other unwrapped hoop.
Step 4: Step 4
When both small hoops are wrapped together tie string onto the hoop with a yarn tied on in each fourth section of it like the image as shown. Do the same thing to one of the medium 6" hoops.
Step 5: Step 5
When the starter sections are made, with the two 4" and one 6" hoop start to wrap and tie the yarn around and through randomly until the inside of the hoop is evenly spaced out and covered in yarn.
Step 6: Step 6
Hot glue the 6" hoop that has been covered into one of the 10" hoops.
Step 7: Step 7
Tie one end of the yarn to the small interior 6" hoop and begin wrapping the yarn from the medium-sized hoop to the large hoop with about an inch of spacing in between each wrap.
Step 8: Step 8
To the remaining two hoops start again by knotting the yarn onto a side of the hoop.
Step 9: Step 9
Start to wrap the yarn straight across the hoop and repeat with about a half an inch in between each wrap.
Step 10: Step 10
Continue wrapping as so until both hoops are covered.
Step 11: Step 11
Place the two small hoops at the bottom with a medium hoop above it and one big hoop on each side of that and hot glue together. Congratulations! You have finished!
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Multi-Discipline Contest
