Drip Irrigation Using Pet Bottle
1,070
About: "May the good belong to all the people in the world. May the rulers go by the path of justice. May the best of men and their source always prove to be a blessing. May all the world rejoice in happiness. ...
Use a pet bottle to feed your plants:
1. Make a small hole on the bottle cap using a safety pin.
2. fill the bottle with water and put the cap on.
3. Invert the bottle and push it gently in the flower pot or in the garden.
4. This will keep the soil moist for a few days, even when you are gone on holidays for a few days or should you forget to water the plants when you are busy.
5. This concept can be applied to water pipe / tube at every 10 feet or so, if your garden is "long" ! (Arrange inverted pets at every 10 ft on water pipe like saline drips on patients in the hospital. puncture the tube so that it feeds the pet bottle at the (inverted) top ! ;-D )
Hope it was useful.
reg
ketan
Supplies:
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    7 Discussions
    admin
    10 years ago
    Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
    jamatran
    8 years ago on Introduction
    Is there a way you can do this by cutting the bottoms off the bottles so when it rains you still retain water. I have had times where I was gone for months at a time so its hard to water your garden.
    pandyaketanjamatran
    Either use more bottles if u have a larger area or use a big drum with a small pinhole so that the water drips for months, if the area is small. You may also try many such pinhole drums over larger area. Principle is - some water is better than no water, i guess....
    reg
    ketan
    May rain come in time and plentifulness be on Earth.
    May this world be free from suffering and the noble ones be free from fears"
    ---- Vedic blessing
    finton
    10 years ago on Introduction
    Re juancho's question: I imagine that would be an advantage. when the temperature rose and the plants needed more water, the pressure inside the bottle would increase and force more water out. Cold temps would shrink the bottle and retain water(?).
    pandyaketanfinton
    Thank you all ! The Idea is to send the message across that its possible. You may modify, alter and innovate based on your own imagination and experience.
    Thank you once again.
    reg
    ketan
    canno
    Great idea is this gravity powered, if it is won't the pressure decrease as more water drips You could also use a pringles can, and poke a hole on the plastic cap it would store a lot more water 3/5 the pictures aren't there, instructions could be more clear and more detailed explanation needed this guy xP
    juancho98
    I am interested in beginning "drip watering" of garden plants. Is there any problem with the water temperature, when the water in a pet bottle or any other bottle heats up in the sun? John
