Drum Lamp
I found a drum in the trash can, the skin was damaged. I kept it for long in my garage, and finally decided to make a lamp. It is a good gift for a drummer.
Teacher Notes
Step 1: Making Of
After removing the damaged skin, I could work inside.
The drum has already some metal fittings to attach the drum. I used one fitting, and moved another fitting in front.
Through these fittings I installed a metal tube, I had to drill the side of the drum to allow the metal tube to go through the fittings.
On the tube, I attached the sockets for the led bulbs with plastic Tyraps and connected the wires.
The drum is light, and I attached the electric wire to the tube to hang the drum.
To hide the leds, I put a meshed fabric that I attached with drum skin attachment.
Done!
I first published this instructable in my blog, you can visit it for more articles.
olivierbricole
Indoor Lighting Contest
This is an entry in the
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
