Introduction: Duct Tape Data Cable
Hello friends i think you are also tired of old data cable for charging your smartphones.In this instructable i'm going to taught you to make a duct-tape data cable which can later be folded and opened for use.
Step 1: Materials Required
Now, we're going to make the duct tape data cable. so we need some material to make it.
So, here's the list of material required to make this project.
Materials
- Duct tape
- copper wire
- an old data cable
Tools
- scissor
- plier
Step 2: Open the Tape
First open the tape and cut the length how long you want and then paste the small amount of the tape to the ground like given in the image.
Step 3: Cut the Copper Wire
Now take the copper wire and cut two equal part of the copper wire.Be sure that the length of one copper wire is greater than the tape.
Step 4: Remove the Insulator From Copper Wire
To make the copper wire to conduct electricity we need to remove the copper insulator from the both side.Do not remove the insulator more than 1 cm.
Step 5: Paste Copper Wire on the Duct Tape
Now paste the copper wire on the duct tape .paste the copper wire parallel to each other and after it cover the copper wire with another duct tape on it.
Step 6: Cut the Data Cable
First cut the both end of the data cable. Be sure to cut the wire from the after 4-5 cm.
Step 7: Cutting the Wires
Now remove the plastic insulator from the red and black wire as they are the charging wire of the data cable.
Step 8: Connecting the Wires
Now connect the wires to the copper wire. the red wire is the positive and the black is negative. be sure to connect the both end of of red wire to the same copper wire and the black wire to the same copper wire.
Step 9: Final Step
Now you need to soldering the wire and covering the insulated wire with tape to avoid the wore to be touched to each other.
Step 10: Completed
Now you have a duct tape data cable which you can fold when not in use and open it when you want to charge your phone.
Trash to Treasure Contest 2017
Duct Tape Challenge 2017
