Duct Tape Wallet for a Backpack
Introduction: Duct Tape Wallet for a Backpack
When I realized my wallet couldn't hold as many things as I wanted it to when I made it, I decided to make a new one. So I began plotting out a new design. This new one would not only hold any money I need, it would also hold my phone and other things, such as a portable charger. The wallet wouldn't fit well in my pocket, so I decided to make it as a wallet that would go inside a backpack. Design in mind, I began work.
***Notice*** This is my first Instructable, and any suggestions or constructive-criticism are welcomed.
Lets get into this!
Teacher Notes
Step 1: Materials
All the materials needed for this project are listed here:
1. Duct Tape.
>I chose Lime Green as my color, but you can chose whatever color you want.<
2. Ruler.
3. Scissors.
4. Pencil.
>Not really needed, as the pencil didn't leave much of a mark on the tape.<
5. Velcro.
>I just used little circle ones that are sticky on the back.<
6. Patience
>Duct Tape is very unforgiving, and will not easily unstick from itself.<
Step 2: Phone Pocket
First I began work on the phone holder. I measured out my phone's height, and adding about a half inch for good measure, I cut out strips of duct tape, and put them together to create the main body. I then put together a few strips for the pocket (see the pictures), and attached it to the front. I made the pocket at a specific height, where I can read messages without having to pull the phone in and out of the pocket. I test-fitted the phone and began work on the next part.
Step 3: Wallet
Now for the part of this wallet that will hold the money. First I made a cylinder that i folded (see pictures) to make a pocket that can open up for more storage. I made another body piece (doing the same thing as the previous one) and attached this "pocket" to it.
Step 4: Accessory Holder
This piece is made very similarly to the phone case. I measured out a sheet of duct tape in the size of an Altoids tin, and then wrapped a thin sheet around it to make a pocket. I closed up the bottom with a few strips of tape, and tried putting a few things into it. The Altoids tin fit, but in the final product, was to thick to let the wallet close. I decided instead to use it to carry a portable charger, which was much more useful to me.
Step 5: Putting It All Together
Time to put this together! I placed the phone case and accessory holder together and separated them just a bit. I put two strips of duct tape on the top and bottom, and then flipped it upside down and placed two more strips on top of the others. I did the same with the wallet section, and then put the items inside. I closed it up, and added Velcro to keep it closed.
Step 6: Closing
Thank you for reading this Instructable! Please give me suggestions on how to improve this, creative criticism is encouraged! Thanks!
Stick It! Contest
Stick It! Contest
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    Fun project. There is nothing that you can't do with duct tape.
