Introduction: Dutch Oven, Fruit Medley Cobbler
One cobbler to rule them all (or at least their taste buds). Make a Dutch oven dessert that will make everyone happy.
I make a Dutch oven dessert almost every time we go camping because they're so easy to make. I'll ask the kids what flavor of cobbler they want and I'll get a different answer from each one. So I had a great idea to make one cobbler to fit all their requests.
This experimental recipe was based on my normal cobbler recipes. It looks and sounds fancier but was just as simple to make and it turned out great. The kids loved being able to choose one or all flavors, and I loved being their culinary hero once again.
Step 1: Ingredients
1 can red raspberry pie filling
1 can blueberry pie filling
1 can peach pie filling
1 yellow cake mix and required ingredients (mine called for 3 eggs, 1/3 cup vegetable oil, and 1 cup water)
* As a side note, you could choose to use any fruit pie filling flavor you wanted (strawberry, apple, etc).
* Another option is to use two or four flavors.
Tools and Utensils
12" Dutch oven
Can opener (if your pie filling doesn't have pull top lids)
Spoon and mixing bowl
Briquettes and a match/lighter
Tongs to handle hot briquettes
Tool or glove to handle a hot Dutch oven
* I like to use a chimney starter
Step 2: Preparation
Start by lighting the briquettes so they can be ready when you start cooking in about 15 minutes.
Lightly oil the bottom of the Dutch oven.
Spoon the cans of pie filling into the bottom of the Dutch oven, keeping each flavor separate from the other.
Prepare the cake mix and required ingredients as directed.
Spoon the cake mix over the pie filling, making sure not to mix the pie fillings or the cake mix.
Step 3: Cooking
Cook in a conventional oven for 34-38 minutes at 350°F.
Or
Cook using briquettes for 34-38 minutes at 350°F by placing 10 briquettes under the Dutch oven and 16 briquettes on top of the Dutch oven.
Rotate the entire Dutch oven 1/4 turn and the oven lid 1/4 turn the opposite direction every 7-10 minutes for even baking heat.
Step 4: Serve and Enjoy
Serve and enjoy your new found hero status.
Optionally garnish with whipped cream or ice cream.
A few more tips for cooking with a Dutch oven
To know how many briquettes to use on top and bottom use the following formula for 325°F heat:
- Place the same number of coals under the oven as the pot diameter minus three.
- Place the same number of coals on top of the oven as the pot diameter plus three.
To increase or decrease the heat in increments of 25°F:
- Add (or remove) one briquette each to the top and bottom for every 25°F
Therefore our 350°F cooking temperature is:
- Bottom = 12(for the diameter) - 3(for the rule) + 1(for the extra 25°F) -> 10 briquettes on bottom
- Top = 12(for the diameter) + 3(for the rule) +1(for the extra 25°F) -> 16 briquettes on top
One trick I use is to mix the cake mix at home, put it in a zip lock bag, and just pour it over the pie filling when I'm ready to cook.
Last tip, I like to use heavy duty tin foil to line the bottom of my Dutch ovens when cooking sweet desserts. The sticky sweet food doesn't come off as easy as I would like.
Grand Prize in the
Outdoor Cooking Challenge 2016
Makerspace Contest
Outside Contest 2016
