E Waste Component Earrings
Introduction: E Waste Component Earrings
About: I'm always fixing, making, designing or restoring something. Then doing it all again.
Recycled electronic component earrings made with resistors
Supplies:
12 resistors (6 for each earring) 2 earring hooks
Teacher Notes
Step 1:
You will need 12 resistors and a skewer to wrap the wires into loops
You will also need an earring hook if you are using old resistors which may contain lead
Step 2:
Wrap each resistor wire around a skewer till you have 10 in total
Step 3:
Join 5 together end to end and form into a circle
Step 4:
Using the extra resistor, wrap it under skewer and join the circle of resistors by wrapping till its secured
Step 5:
Attach an earring hook to end of resistor by wrapping it through
Step 6:
Your done
Step 7: Alternative Designs
Wearables Contest
This is an entry in the
Wearables Contest
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
    5 Discussions
    DamianS70
    DamianS70
    23 days ago
    Yumm Lead Poisoning
    tigoda
    tigoda
    4 weeks ago
    these look very very cool, I love the idea of them immensely!
    however, as much as i don't want to be "that guy", you might want to consider using actual jewellery findings for the bit that goes in to you, the legs on those things are all manner of nickle and tin and on very old resistors might even be lead, it depends when and where they were made but non of the usual metals are body safe.
    lindafrib0
    lindafrib0
    Reply 4 weeks ago
    Thanks mate. Will add hooks
    ajoyraman
    ajoyraman
    4 weeks ago
    Instead of 10 Ohms if you had used 1 K's it would have been a 12K earring set. Resistors are always lying around. Great work! You have my vote.
    audreyobscura
    audreyobscura
    4 weeks ago
    Nice way to recycle components if you're not going to use them.
