*EDIBLE* Instruments!?
Introduction: *EDIBLE* Instruments!?
Whats better than the sweat sound of music?
FOOD! So why not combine these two loves to create the ultimate combination? Look no further, this instructable is a step by step guide to food heaven!
Supplies:
All you need:
  • vegetables
  • clean drill bit
  • sharp knife
Teacher Notes
Step 1: Basic Shaping
For the purpose of this lesson I will be using a carrot but you can use whatever you want.
There are two main components to making this whistle:
  • the mouth piece
  • the finger holes
First of all top and tail the carrot, removing about an inch from the pointy end. Then take the drill bit and with fingers carve a uniform hole starting from the blunt end and ending just before the pointy end forming a cavity. Now shape the mouth piece (pointy end) to fit your mouth.
Step 2: Final Touches
To finish:
  1. cut a notch and diagonal (above image) about half an inch from the mouth piece half way through the drilled hole.
  2. carve a small piece of off cut to fill half of the chamber from the mouth piece to the notch.
  3. use a smaller drill bit to drill smaller finger holes.
  4. build as many as you can and start an orchestra with your friends!
Step 3: The Edible Part!
When your finished with your instruments why not make a creamy roast vegetable soup? Or how about some carrot sticks? Your imagination really is your limit!
Hope you have fun with this one; if you do please consider voting for me in the instrument contest. :)
Instrument Contest
Instrument Contest
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
