ESP8266 8 Channel Relay Home Automation
Introduction: ESP8266 8 Channel Relay Home Automation
About: Hello Friend
Hello All Friend
Here Is My 1st Custom PCB Project ESP8266 8 Channel Relay Home Automation . Thanks To PCBWay For High Quality PCB ...
Step 1:
This Board Is 100mmx100mm
Used WeMos D1 Mini Module 5 v Relay 150 Ohm Resistor For 8+1= 9 LED 8 Blue LED For Every Realy 1 Red LED For Power Used 3mm LED Used ULN2803 Relay Driver Used 8 3p Terminal Bluck Used 2 2p Terminal Bluck One 7805 For Optional If You Do Not Want To Use 5v Power Supply Used HLK-PM01 220-240v To 5v Power Supply
Step 2: Solder All Component
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    • Audio Challenge 2020
    5 Discussions
    WillianG
    WillianG
    1 year ago
    Hello, thanks for sharing the project, theres a detail, the uln2803 already has a bult in clamp diode, so you don't need those extra in the pcb.
    MyTechRock
    MyTechRock
    Reply 1 year ago
    Many Thanks Sir I Will Take Care This On My Feature Project
    Welcome to Instructables. Thanks for sharing with the community.
    ManoranjanD2
    ManoranjanD2
    Reply 1 year ago
    Many thanks sir
