Easy Beginner Magic Trick
Introduction: Easy Beginner Magic Trick
Supplies:
normal deck of cards
Teacher Notes
Step 1: Setup
get three diamonds
three clubs
and three hearts
Step 2: Explain the Trick
get three clubs, three diamonds and three hearts
then put the three clubs in a pile like on the photo then do the same with hearts and diamonds.
then say at the end of the trick that all of the cards will be groups like they are now
Step 3: Put the Cards in Three Piles
ask them to pick a deck of hearts, clubs or diamonds
then mix the deck of cards they choose
then put them on three separate piles
then do the same three times
the end result should be the same as the second picture
Step 4: Make Three Piles Into One Pile
ask them which pile they want at the top and with one they want on the bottom
by asking them you make them feel like they are in control and that also makes them more surprised when the trick works
Step 5: Make Your Magic Trick Look More Like Magic
ask them how much times they want you to split the cards
when you split the cards you put the top part to the bottom (it doesn't mater how many cards you split)
Step 6: Ask the God of Cards
make a story about the gods of cards to make it look more like a actually magic trick
Step 7: The Actually Magic Trick Starts
spell club not clubs and then put every time the card to the back when you said a letter like on the video. then one letter b put it on a pile
Step 8: Do the Same With Heart and Diamonds
know do it with hearts. so spell heart and then put a card to the back of the pile and at t put it on a new pile
do the same with diamond but then put the card on a new pile.
you should have three piles of one cards
Step 9: Do the Same
do the same but then start at the other side but still start with club then heart then diamond
Step 10: Nearly Done
do the same as step 8 but then again the other side like on the video
Step 11: Finish
you should have three piles of three
there should be one pile of hearts one pile of clubs and one pile of diamonds.
Step 12: I Hope You Can Blow Your Family Away With This Trick
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
    2 Discussions
    Ryan Somefun
    Ryan Somefun
    Reply 21 hours ago
    thanks
