Easy, Low Cost Hoop House
I grow a lot of kale in my garden, and the last 2 years the caterpillars have been eating more than I do. I do not use pesticides. I decided this year I would cover this area with netting to try and prevent or at least minimize the eggs getting laid on the kale. It is a small white butterfly that starts laying eggs in June, and by July the caterpillars are eating large holes in the kale. I also decided that I can cover the area with plastic until it warms up so that I will get some kale earlier. It is April 15th and there is a lot already growing. I have been keeping the area covered with plastic. The area I covered is about 12 feet by 7 feet. I went to the local home improvement store and bought 8 - 24 inch pieces of rebar($1.75 each), 4 pieces of PVC 1/2 inch by 10 foot($1.85 each), and at Walmart I found a roll of plastic for $15. It is 20' by 25'. I also had some dollar store zip ties that I did not need to buy.
Step 1: Putting in the Rebar
When I was putting in the 1st piece of rebar I noticed that the top was getting flattened out, so I covered it with a socket to help prevent the damage. The PVC needs to fit over the rebar so it needs to stay round. The spacing I used was approximate 7 foot from side to side, and for the length about 3 feet from bar to bar. The rebar is 24 inches long, and I left about 12 inches sticking out.
Step 2: Assembling the Frame
The PVC was a little tight going over the rebar, but this will help it from coming off.
Step 3: Adding the Cover
It was very windy today, and I was by myself, so it was a challenge getting this on without it blowing away. I used 4 zip ties on each tube. This should hold it. If not I can add more. I plan to leave this on for 2 -3 weeks, and then I will remove the plastic and install the netting. The netting I have is from walmart and it's in 10 by 14 foot sections. It was $6 a package. I bought extra because I will overlap the netting to get better coverage. When it gets cold I will reinstall the plastic so I can extend the growing season as long as possible. This took me about 2 hours to so, I would hope it will last 2-3 years. The extra vegetables I will get will be worth the low cost and ease of building this.
Step 4:
Gardening Contest
This is an entry in the
Gardening Contest
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    5 Discussions
    ronanry
    Tip 1 day ago
    What you can do (as i saw on a "real" greenhouse) is to weld a piece of metal on the rebar so you got a shape like a 1.
    That way, you can tie a string all over the greenhouse to keep it in place (instead of zip tie which lead to hole, and bigger hole and bigger and bigger with the wind coming)
    aaahotdog
    1 day ago
    Electrical conduit can probably take the UV better, however, it is twice the price of plumbing pvc pipes. Good luck with the caterpillars. I feel your pain.
    CaseyCase
    Tip 1 day ago
    I recommend using pvc electrical conduit instead of pvc plumbing pipe for this project. The pvc electrical conduit is made to resist sunlight exposure and is less expensive than the plumbing pipe. PVC electrical conduit is grey in color, FYI.
    jessyratfink
    1 day ago
    I've been thinking of putting in one of these to extend my growing season a little bit! I hope you outsmart the caterpillars this year :D
