Easy No Bake Milk Pie
886
Introduction: Easy No Bake Milk Pie
This pie recipes is easy to make. No bake, no need much time, but the result is delicious.
If you make this pie, you will like the taste and love to make it again because the recipe is simple.
Step 1: Prepare the Ingredients
Pie crust:
80 grams fat, like butter or margarine. I used margarine
1 glass flour (150 grams)
1 egg (in this recipe I using duck egg, but it will perfect using chicken egg)
Pie filling:
3 egg yolks
3 sachet consended milk (around 80 ml)
2 glass warm milk (360 ml)
50 grams corn flour, watery it with 100 ml water to make it liquid (optional)
A pinch salt (optional)
If you like sweet taste, you can add sugar into the filling
Tools:
30 centimeters non stick pan
Whisk
Rolling pin (optional)
Step 2: Make the Pie Crust
1. To make the pie crust. Mix margarine with flour.
2. Knead it well until perfectly mix.
3. Add egg to the flour mixture. Make sure the egg was in the room temperature, not too cold from fridge.
4. Knead it well and voila, you get the pie crust.
At this recipes I'm divide it two because I using small pan, so from this recipes I get two pie.
Step 3: Shaping the Crust
At this step, I prefer to shaping the crust direct to the teflon or pan. Just shaping it using hand.
But, you can using rolling pin before put it to the pan.
Use big pan with diameter 30 cm.
I using small pan, 20 cm, so I can get 2 pie from this recipes.
Make sure you make smalls hole with fork to prevent air buble. So the crust will not blow.
Step 4: Make the Pie Filling
1. Mix the egg yolks, consended milk, and the milk using whisk. At this step you can add sugar and salt.
2. Mix it well until all the ingredient well mixed.
3. Pour the mix milk to the crust. Sieve to get smooth mixeture. Make sure there is no lumps.
Step 5: 'Bake' the Pie
1. Turn on the stove with small heat, put the lid and bake the pie on the pan 15 minutes until the milk filling congealed.
2. After the pie is cooked. Let it cool, so the milk filling will harden and the pie is ready to serve. Selamat makan.
Pie Contest
Pie Contest
Be the First to Share
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
    4 Discussions
    Elaina M
    Elaina M
    Question 1 year ago
    This looks great and a perfect way to use the Duck eggs I just got. I am unfamiliar with the consended milk powder you use in step 4. Is this similar to powdered milk ?
    Asyamra24
    Asyamra24
    Answer 1 year ago
    Hi! I'm using ordinary consended milk, liquid consended milk.
    actually you can replace consended milk with cow milk, powdered milk, etc. But you should add extra sugar for get the sweet taste.
    Thank you for asking :D
    Hamartia MacGuffin
    Hamartia MacGuffin
    Question 1 year ago on Step 2
    "One GLASS flour"?? Could you provide an actual quantifiable measurement, please? Preferably by weight, not by volume (for the flour, anyway -- please provide volume measurement for milk).
    Asyamra24
    Asyamra24
    Answer 1 year ago
    The flour Around 120 grams, and the milk 180 ml.
