Easy Perfect Straight Cut Aluminum Sheet
Introduction: Easy Perfect Straight Cut Aluminum Sheet
About: Love DIY things .
Aluminum is an easy material to build cases cause it is good to work , but to get a good result is necessary some good tools. Sometimes simple techniques are enough to get a good final result , that is what i gonna show in this instructable .
Teacher Notes
Step 1: Material Required
  1. stylet
  2. set square
  3. aluminum sheet
Step 2: Cutting
Use set square and hold it tight , with the help of your other hand press and slide stylet until desired marked position . Once or twice is enough .
Step 3: Bent
Bent aluminum sheet to break it .
Step 4: Cut Comparisson
Comparing result is clearly better . Another cut on pictures were made with scissor .
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
    2 Discussions
    Alex in NZ
    Alex in NZ
    1 year ago
    Good idea. Thanks for sharing it :-)
    E_Alves
    E_Alves
    Reply 1 year ago
    Not at all .
