Easy Popsicle Stick House
2,231
This is an easy and fun craft you can do to pass the time or do with your kids. It is inexpensive and relaxing and it is good decor for your garden or room.
Teacher Notes
Step 1: What You Will Need
1. Hot glue gun and glue ( use if wanted a paper plate to protect table or other surfaces )
2. popsicle sticks ( Use different colors if wanted )
3. Scissors
Step 2: The Walls
Take two popsicle sticks and lay on table and glue about 8 popsicle sticks between them. Use what ever colors you want. Make 4 and set aside.
Step 3: Make the Door Way
cut three popsicles in half. 1 of the halves will be part of the back popsicles. Lay a popsicle on the table with 1 of the halves. Glue popsicle between then and use the halves to make a door way. I will not make a door but you can make one if you want.
Step 4: Assemble
You should have 5 walls, 1 will be the roof. Glue how you please. I glued them to gather to make a box then I glued the roof on.
Step 5: The End
You can make it as elaborate as you want, this is just a simple design.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
