Easy Propeller Pull Toy
This little toy is easy to make and fun to play with. I came up with this idea because i like to make things and I wanted to make something that could fly. so here it is. have fun making it and playing with it.
Supplies:
Tools
1. Saw
2. Knife
3. Hot glue gun
Fot the toy you will need:
1. Propeller (you can make one yourself)
2. Small pice of pvc
3. 2 bolds (size 8)
4. Wire
5. Small stick or handle
6. Longer straight stick
Teacher Notes
Step 1: Prepare the Propeller
The propeller need to be attached to the longer stick. Make sure the stick is straight, otherwise the stick wouldn’t get out of the tube.
I attached the stick to the propeller with hot glue.
Make several to fire faster
Step 2: Preparing the Launcher
I made the launcher from a pice of pvc and two bolds. Use the saw to get the pvc tube in the length of your hand. Then glue the bolds on both ends.
Step 3: Preparing the Pull.
Take a pice of wire, and use the scissors to cut the wire in the length of your arm. And attach it with a knot.
Step 4: Fireee!
The last steps are easy. twist the string around the stick of the propeller. then place the propeller with the string in the launcer, and pull.
Make It Fly Challenge
Be the First to Share
    • Skateboard Contest
      Skateboard Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    2 Discussions
    Jipjap.seamster
    Reply 4 weeks ago
    Yes it really is, and it's easy to make
