Introduction: Firecracker
This an Firecracker I made in my spare time. When I get time I'll post an instructable on how to make the igniter.
Step 1: Lettuce Begin
Okay First You need An Igniter Like https://www.instructables.com/id/Remote-Ignition-System-Camera-Flash-Method/ A Knife, Steel Wool, Box of Matches, Paper, Electrical Tape, and anything you can find to grind match heads (Except Granny False teeth).
Now take the knife and scrape the match striker you will be rewarded with Potassium perchlorate. Next grab a match or two and crush the heads and be rewarded with Red phosphorus (Avoid crushing the wood off too). Do not mix the Potassium perchlorate and Red phosphorus yet.
Step 2: Mix
Carefully Mix the Two powders By Shaking the paper. As soon as that is done it becomes heat, friction, and shock sensitive in other words be fricken carefull. Tear a piece of tape of and pour about a match head amount of powder onto it. Next take the steel wool and lay it across the powder on the tape (Warning don't try to rip the steel wool with you hand it cuts into skin like a hot knife on butter). Now roll the tape up.(In the picture the gray is steel wool and red is powder For those blondes like myself
Step 3: Ready for Ignition
Attach it to your Igniter and Let it rip.
Trouble shooting.
If it does not ignite you may need thinner wire or more power
The small print.
I don't take any responsibilty for any loss of eyebrows, Eyes, limbs or the abilty to move.
