Easy Tiered Garden Bed
About: Beginner-focussed DIY, Home Improvement and Woodworking tutorials and videos.
Learn how to build this tiered raised planter using cedar fences and 2×4s. It is a great planter for patios and decks to plant flowers, herbs or vegetables.
The frame is built using 2x4s and then wrapped with cedar fences. This keeps the costs really low.
Supplies:
  • lumber per the plans
  • Corner Braces (optional)
  • Corner Plates (optional)
  • Miter Saw
  • Kreg Jig
  • 2½” Outdoor pocket hole screws
  • Power Drill
  • Random orbital sander and sand paper in various grits
  • Outdoor finish (optional)
  • Landscape fabric
  • Staple gun
Teacher Notes
Step 1: ​Step 1 - Make Cuts and Prep
Follow the printable plans and make all your cuts. Sand down the boards and make pocket holes with a Kreg Jig set to 1½"
Step 2: STEP 2 - Build Frame
Attach a rail to the shortest legs and attach the supports using pocket hole screws.
Similarly, build the middle and back leg frames.
Then, go ahead and attach them all together to make the frame for the tiered planter.
All the joints are made using exterior grade 2 1/2" pocket hole screws.
Step 3: STEP 3- Attach Cedar Planks
Attach cedar planks at on the inside of the frame to make the bottom of the planter and also all around the frame.
I used corner brackets to attach because it also looks good, but exterior grade screws will work too.
Step 4: STEP 5- Attach Lattice Trellis
Attach a lattice to the back of the 2x2 frame using a pin nailer or brad nailer to make a trellis.
Step 5: STEP 6 - Plant Your Favorites!
Make drainage holes in the bottom cedar planks.
Attach landscape fabric to the inside of the planter and plant your favorite herbs, veggies or flowers.
Planter Challenge
Planter Challenge
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    audreyobscura
    7 weeks ago
    Dang, I really need to get a kreg jig!
