Introduction: Easy Way to Make Free Fuel From Sawdust and Paper (Short Video)
About: Lateral thinker, Originator of Inclined Bed Therapy (IBT) Originator of Pocket Full Of Acorns Project. Originator of Operation OASIS.
A simpler way to compress paper and sawdust briquettes using your body weight instead of your hands.
This method applies far more compression pressure, producing much more solid briquettes.
We are now able to use the waste from the chainsaw together with the junk mail and cardboard packaging that arrives daily, to heat our home log burner.
Before this, we would get in a mess, trying to feed chainsaw wood shavings into the fire, adding kindling to burn it.
This produced far too much smoke and stifled the flames. And annoy the wife :)
Now we are stock piling paper and sawdust briquettes for the winter.
This method is very quick and easy
Step 1: You Will Need a Large Tub to Soak Newspapers and Mix in Saw Dust and a Plasterers Mixing Paddle
We used a large planter that we use to hold logs next to our log burner.
This was the ideal size.
Junk mail, cardboard packaging, newspapers, magazines are torn into smaller pieces to make it easier to blend. Paper shredder waste is ideal.
Avoid dust from MDF and Chipboard as this will release toxic acrid smoke.
Add to a 2/3 water filled container and soak for 3-4 days or longer until it comes apart easily.
Attach plasterers paddle or paint mixing paddle to your drill and mix thoroughly
Add as much sawdust as you can get in, while mixing with the paddle
Add more water if required.
Step 2: You Will Need to Buy a Paper Briquette Maker (Ours Cost £3.50 From a Second Hand Store)
Fill the briquette maker with the mixed paper mulch and sawdust / shavings from the chainsaw, or obtain from other sources, using the brush and pan to keep things tidy:)
Adding sawdust will make the paper logs burn longer with more heat.
The briquette maker is designed for use with your hands.
The problem with this is that it requires a lot of effort and those handles dig in after long use.
We added a plank of wood, which is placed across both handles.
Now you can step on the plank, taking care to steady yourself (Don't want any accidents)
More water is expelled using this method and the blocks / briquettes are more efficiently compacted, making easier handling and burning.
Step 3: Store Your Paper Logs in a Dry Place
Store paper blocks where they can dry out. Ideally in a place where air is circulating, such as outdoors under a roof of some description.
Storing in a shed can result in mould forming due to excess moisture evaporating.
Now you can smile when junk mail drops through your letterbox.
You can also make paper and cardboard briquettes
Paper briquettes are a great way to use up old newspaper and magazines. Simply soak the paper in water, place the pulp into the maker, place wood plank on the handles and step on it. After drying, your briquettes will be ready to use as fuel!
Briquette Makers measures around 34 x 16 x 12cm.
*Recycle old paper and magazines *Suitable for barbecues and chiminea
And most of all, do your bit for the environment by diverting useful waste from landfill
My website: http://inclinedbedtherapy.com
Step 4: Burning the Dried Out Briquettes
Here is the long awaited burning test.
The dried briquettes are now ready for their final destination.
The video shows how well they performed in a cast iron multi-fuel stove.
Hope you enjoy it
Fire Challenge 2017
Runner Up in the
Fire Challenge 2017
Before and After Contest 2017
