Easy and Versatile Crock-Pot Chili: Texas Style
In this Instructable I show you how to make a chili as spicy as you want! No matter what your preference of heat, you can make it easy with a simple variety of options from your local grocery store!
Teacher Notes
Step 1: Ingredients
Mix and match your available options to your preferred Scoville and taste. You can choose all hot and 9 alarm, or go as mild as you want. Inside the parenthesis are what i used for this batch. I made the heat level what I call mild, but other people i know call hot.
6+ Quart Crock-Pot
2lbs. 80/20 Ground Beef
16oz. Tomato Paste (I use a Tabasco Chili Starter for heat and taste)
16oz. Can Kidney Beans (with Spicy Chili Sauce)
16oz. Can Black Beans
4x 12oz. Cans Rotel (2 Original, 1 Chipotle, 1 Hot)
1 Purple Onion (medium sized or half a large)
1 Chili Seasoning Packet (mild)
Step 2: Mix Together Cans and Seasoning
In this step, add the tomato paste first, then drain all your liquids from your other cans into the tomato paste can. This liquid will be added back in at a later step.
Once all cans are in your pot, you can start the heat.
Step 3: Prepare the Meat
I like to sauté my onions in my ground beef to soften them and make the final texture of the chili more consistent. If you like crunchy onions, don't cook them in this step.
Dice up your onions before you start cooking the ground beef. I set my stove top to medium high heat. Ground beef with this high of a fat content doesn't need any oil added. When a sufficient amount of grease is in your pan during the cooking process, you can add in your onions. Cook until all your beef is browned, then drain the fat into one of your empty cans.
Step 4: Combine, Set, and Forget
Self explanatory. In this step pour your ground beef in the crock-pot and stir in. At this time you can add in the liquid you set aside to your desired amount. It just so happens that the liquid in all the cans brings it to my perfect desired consistency. Set your crock-pot for your desired cook time. I cannot stress enough that you should never leave your crock-pot running while no one is home.
You can cook this in a stove top pot by bringing it to a boil and stirring the entire time, then simmer while stirring occasionally for 30 minutes. This is method is quick, but doesn't let all the juices mix like in the crock-pot. It still makes very good chili.
Step 5: Enjoy!
I like to eat my chili with my favorite chips, sharp cheddar cheese, and sour cream. Pick your favorite toppings and enjoy!
Spicy Challenge
Spicy Challenge
Be the First to Share
    • Kitchen Skills Challenge
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
    2 Discussions
    Kink Jarfold
    4 weeks ago on Step 5
    We ALWAYS had Saltines with our chili. Yours sounds great.
