Easy Cable Clip - Sucker Version
21,318
140
19
Introduction: Easy Cable Clip - Sucker Version
About: Openproducts' focus is on design of new products and on innovative approaches towards improving existing products. An example: the CountClock, a concept facilitating children to learn telling the time. Purpo...
This instructable introduces an alternative design for a cable clip, based on a previous openproducts design: instead of screwing the clip to a wall or a closet, it features a sucker cup, which allows to stick the clip on a window, a tile or other smooth surfaces. This makes it easier and quicker to hang up the clip, but at the same time it is (slightly) less robust. These sucker-version cable clips are available in the openproducts webstore.
The design of the 'cable clip from tubing' (published on 13 September 2012 under CC by openproducts, https://www.instructables.com/id/Cable-clip-from-tubing) is simple but functional: it is a user-friendly clip from which cables can be hung vertically as a way to store them and thus to prevent the cable from raveling. In addition, the cable is exposed less to wear and tear.
According to user feedback on this 'cable clip from tubing' a barrier for installing the cable clip was the fact that it needed to be screwed: it appears that people sometimes are reluctant towards affecting walls and skins of closets and jambs inside their homes.
By using a suction cup for making this alternative easy cable clip this barrier is being removed.
Based on an existing suction cup the easy cable clip is very easy to make, without any special skills or tools: two cuts with a simple knife is all it takes to upgrade a suction cup into an 'easy cable clip sucker version'.
Alternatively, cut-and-dried cable clips are available from the openproducts webstore in two variants: 1.) a sucker version and 2.) a screw version.
In step 7 some words are being spent on explaining why this clip is innovative.
Teacher Notes
Step 1: Find a Suitable Suction Cup
This instructable is based on a suction cup with a 4 mm (0.16 in) crosswise hole. Variants may also be applied, but the advantage of this one is that the intended cable-lead is already present.
Step 2: Slicing the Clasps
Two cuts need to be made in an X-shaped fashion with a sharp knife. Using a pair of (small) scissors is also an option. After removing the material at the exterior sides, the two remaining triangular clasps constitute the fastening clip.
Step 3: Stick the Sucker-clip to a Smooth Surface
Find a window, a tile or another suitable smooth surface and clean it with soap in order to degrease it. Moisten the suction cup and stick it onto the surface. Make sure that enough space is reserved to let the cable hang out freely. Alternatively, stick a series of sucker-clips in a row.
Step 4: Learn How to Use the Clip
Like for the 'cable clip from tubing' it is important to get familiar with your new sucker-clip. You need to pull the cable skillfully in order not to ruin your expensive headset (see step 6 for all detail: https://www.instructables.com/id/Cable-clip-from-tubing/step6/Learn-how-to-use-the-clip).
To hang the cable: position the cable in the upper triangular opening while leaving a few centimeters of space towards the connector. Push the cable gently with a finger of one hand towards the clip while pulling the cable down softly with the other hand. Then let the connector be supported by the upside of the cable clip.
To remove the cable from the clip: gently pull the cable from underneath towards the triangular opening at the bottom until the two triangular clasps release the cable. The other way round is possible as well: then first pull the cable a little upward to free the connector from the clip, then pull down towards the upper triangular opening.
Step 5: Testing the Cable Clip
The sucker-version of the easy cable clip has been put through the same tests as its tubed cousin, the  'cable clip from tubing'. For an overview of the variety of cables tested see https://www.instructables.com/id/Cable-clip-from-tubing/step7/Testing-the-cable-clip.
The case of a mobile phone charger with a mass of 180 g (0.40 lb) is delicate: firstly because the continuous force on the suction cup might loosen it over time, and secondly because the transformer easily bumps against the glass (when stuck to a window) which involves a risk. Therefore, preferably use the sucker version clip with light material, such as connector cables. An overview of alternative objects for using the sucker clip with is provided in the next step.
Step 6: Alternative Objects for Using the Sucker Clip With
As mentioned in the previous step, the sucker version of the cable clip is best suited for light objects. Avoid hitching sharp objects such as knifes and scissors: this may result in injuries in case the suction cup loosens.
As indicated in the pictures suitable objects other than cables are for example toothbrushes and kitchen utensils.
Step 7: Innovative Aspects
The concept described in this instructable has innovative aspects. These are:
 - The clip is made from a standard suction cup, which is thus easily upgraded to have additional  functionality;
 - The sucker version cable clip can and may easily be reproduced;
 - The design and making of the clip is easy and doesn't require complex manufacturing;
 - The clip encloses the cable or other object completely and in such a way that it cannot easily slide out. There is no free space so thin cables (or other objects) will not fall out;
 - The flexible nature of the suction clip makes that it automatically adjusts to thicker cables or other objects;
 - The form of the triangular clasps is multifunctional: it guides sliding the cable in and out and encloses the cable or other object;
 - The solitary design (one clip for one cable or other object) allows to pin up the cables where you need them: one clip to every window, tile or other smooth surface;
 - The cable clip can quickly be stuck to smooth surfaces without screwing and without adhesive tape.
Step 8: License and Webshop
The concept described in this instructable is made available through a Creative Commons Attribution license (CC BY, http://creativecommons.org/licenses/by/3.0), and the innovative part has been described in Step 7.
This instructable is a next step in the development of easy cable clips. The first variant (a screwed version) has been published on 13 September 2013 by openproducts, see https://www.instructables.com/id/Cable-clip-from-tubing for the documentation.
The reader who doesn't want to bother self-assembling the sucker version cable clips can proceeds directly to the author's webshop for purchasing cut-and-dried clips. The webshop is accessible through https://www.instructables.com/member/openproducts.
Commercial use of the concept described here is possible at no costs provided that the name of the author of this instructable, ‘openproducts’ is mentioned, preferably including a reference to this instructable. For other arrangements send a Private Message through the instructables member page (https://www.instructables.com/member/openproducts).
If this design infringes any rights then refer to Article 28 in the Terms of Service (https://www.instructables.com/tos.html).
Instructables Design Competition
Furniture Contest
Furniture Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    19 Discussions
    dana-dxb
    dana-dxb
    6 years ago
    simple and handy thanx for the share i sure gona need this
    RangerJ
    RangerJ
    6 years ago on Introduction
    I have two or three cables I am tired of chasing, so I plan to make some of these as soon as I can get the cups.
    rob2024
    rob2024
    Brillian idea - I bought a bag of ten suction cups recently, I knew they would be useful sooner or later so thanks my cables are all tidy now !
    You can buy packs of them on Amazon under Kitchen & Home, some with built on clips/hooks etc
    openproducts
    openproducts
    Reply 6 years ago on Introduction
    Great. Feel free to share a picture of your tidy cables with the Instructables audience...
    3366carlos
    3366carlos
    very nice. the only thing is that sometimes those suction cups do not stay in place for very long.
    Spokehedz
    Spokehedz
    If you spray a bit of water before you stick them, they stay stuck for much, much longer. I have one in my bathroom that has been stuck for 2 years holding my razor.
    ElectroFrank
    ElectroFrank
    Water with a trace of washing up liquid is even better, probably because it maintains the airtight seal as it dries out.
    openproducts
    openproducts
    I understood that degreasing is the key for success. This indeed goes fine with water and washing-up liquid.
    james.m.k
    james.m.k
    Clean with vinagure and water. The original glass cleaner.
    Then feel the surface, if you can feel bumps, clean with hot water, soap and vinagure.
    Repeat until clean.
    Then lick the sucker before applying.
    openproducts
    openproducts
    Thanks for the comments on licensing @james.m.k and @gcai_fwb. The concept that is being introduced has innovative aspects, which have been described in Step 7. In summary: it's not about the sucker but about the triangular clasps made from a standard sucker. Patenting this feature is a long and costly road, with high risks involved because of prior art aspects. Disclosing the concept in an instructable that is made available under CC BY is an alternative route, attributing the idea to openproducts. A next step could be to find commercial parties that have an interest in the work presented and are willing to facilitate a win-win-win situation. For example, granting a rebate to clients that purchase standard suction cups based on this instructable (win...), thereby increasing their exposure and sales (win...) and spare a few percentages of the additional turnover to openproducts (win!).
    james.m.k
    james.m.k
    Very nice!
    Though I kind of doubt that using sickers to stick things to smooth surfaces is a licenceable thing. Too much prior art. But nonetheless, very nice.
    mdeblasi1
    mdeblasi1
    Nothing like a simple solution to create a more workable world!
    Nice.
    hchiutx
    hchiutx
    6 years ago on Step 6
    Some of the best inventions are simple little things that nobody else thought of. Not quite sure where to get the suction cups though - they are too cheap to be sold by themselves so it's hit and miss at the dollar store?
    Suzanne in Orting
    Suzanne in Orting
    I have seen suction cups for sale in craft stores in reasonable amounts, sometimes singly.
    BigMrTree
    BigMrTree
    Great Idea!! This is so simple yet so fuctional!! nice job
