Electric Longboard for Beginners (0 Code) + Bonus
Introduction: Electric Longboard for Beginners (0 Code) + Bonus
About: I am an Advanced Technician of Electronic Development and I have more than 6 years of experience developing products. I also have experience with raspberry pi, arduino, c, pic... Shall we talk?
I wanted something to move around the city, but I was not interested in scooters, skates, or motorcycles, so I decided to squeeze my brain and I came up with this!
The idea was to make it as simple as possible so that it did not fail, while also being able to reach the highest possible speed.
In this instructable I'll teach you how to make a longboard that reaches 30km/h (with 80 kg) in the cheapest and easiest way (involving zero lines of code).
Stay with me and let's move on!
Supplies:
1.- Longboard (Decathlon or second hand).
2.- Conversion kit for motoring wheels (Ebay).
3.- Motor.
4.- Driver motor (ESC)
5.- Remote control kit (accelerator)
6.- 2 LI-PO batteries.
7.- 6 cage clamps.
8.- Velcros to hold the batteries.
9.- LI-PO charger
10.- Switch.
11.- Voltmeter to see the remaining charge.
12.- Plastic tray to avoid dirt, and so on.
13.- Miscellaneous cables.
14.- Screws.
Teacher Notes
Step 1: Scheme
Step 2: ​Assembly
Assembly The assembly is very simple but requires a bit of skill when joining the conversion kit to put the engine on the wheels, since depending on how the longboard is you'll have to sand the axis a bit. Firstly, we'll put the motor conversion kit on the shaft. Once coupled, we will put in the motor. Next, we will connect the three terminals of the motor to a cage clamp (which will allow us to join the motor to the ESC). Secondly, we'll place the ESC by screwing it to the table, and we will put another 3 cage clamps to attach the ESC to the batteries. By doing this, we could control the connections better. Last but not least, we still have two components left: the RF receiver to send the signal to accelerate the ESC, and on the other hand, securing the batteries with the batteries, once assembled and put everything as in the previous scheme. We'll also add a little improvement, which is to put a voltmeter to indicate the voltage of the longboard so that we can know how much battery do we have at any given time. Finally, you can see attached an illustrative video showing how the longboard works.
Step 3: Bonus
BONUS: Have you mounted yours and you don't know what speed it reaches? Here you have a link where you can download a free application that shows you the maximum speed of your journey on your mobile device (ANDROID).
I recommend using all kinds of protections while using this device;)
Skateboard Contest
Skateboard Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    6 Discussions
    CombatRobotGuy15
    CombatRobotGuy15
    3 months ago
    Where did you get the pulley and pulley hubs from?
    Cierzointernet
    Cierzointernet
    Reply 3 months ago
    Hi! thanks for your comment, (ebay)
    sekitori
    sekitori
    Question 3 months ago
    How about rainy weather / wet roads ?
    Cierzointernet
    Cierzointernet
    Answer 3 months ago
    Hello. Thanks for you comment.
    you should put silicone in the gasket of the case and cover the engine. With these small changes you can go well.
    Bye.
