Micro Electric Piano
Introduction: Micro Electric Piano
I was a mentor for MakerBay and want to document here the project from my student:
The goal is to building and designing an functioning electric piano with the microcontroller Arduino.
Ever since I started learning piano about 8 years ago... my friend started to make music using his computer, I started started to become a little bit more interested in making some music of my own. However when I come up with some chords or melodies, I am unable to play and record it properly on Logic Pro (in the software instrument where I can then edit it afterwards); as such, I end up trying to play it on my piano. Except, if I could have a portable electric piano, I would be able to jot my ideas down on the go, and be able to record it easily ...
This task is highly challenging as it requires the creator to be pretty well versed in electronics, be creative, know coding ... Some more specifics are having the ability to design a functioning piano, create an electrical circuit, and create the product using “final product” type materials.
Supplies:
  • 3D printer
  • with filament in two colors (classic is black and white)
  • breadboard (size depends on the amount of keys you want to have)
  • buttons for arduino (amount is the same as the amount of keys)
  • arduino microcontroller
  • 2-AAA battery holder
  • speaker
  • wire
  • sandpaper
  • wood
  • drill
Research:
Teacher Notes
Step 1: Design the Instrument
Make some initial sketches. They can be done on the computer (with Autodesk Fusion 360 a 3D CAD, CAM, and CAE software) or/and also with pen and paper. The size of the instrument depends on the amount of keys you want to have. If you need to be ready on time you should decide at this point how many functions you want to have because every function will need time. (for example: recording your music, power from battery or power from cable, an external Audio Jack to connect all kind of speaker or just one fixed speaker, just white or also black keys)
Step 2: Coding
The Tone library allows to play tones on a speaker (obviously^^).
The biggest effort was to make playing 3 tones together possible.
Step 3: Building the Circuit
Step 4: 3D Printing
You can use a software like Automaker from Robox to design the parts and send the command to the printer. We printed 3 parts. One for the black buttons and two for the white (or here grey).
Step 5: Testing
Test 3D printed parts with your circuitry before...
Step 6: Measuring/Woodwork
and
Step 7: Assembling
Your Micro Electric Piano is working!
Be the First to Share
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    2 Discussions
    Penolopy Bulnick
    Penolopy Bulnick
    19 days ago
    Fun project! Is there a video showing it working?
    chrismtian
    chrismtian
    Reply 19 days ago
    I updated it just now but I think the website need a moment... never published here something before so maybe it's my fault
