Electromagnetic Field Detector Using an Arduino
4,372
35
5
Introduction: Electromagnetic Field Detector Using an Arduino
Ever electronic device emits a certain amount of electromagnetic fields and we can use this radiation to learn a few things about the circuit.
In today's instructable I'm going to show you how to build your own electromagnetic field meter using an Arduino. This device can be used to detect mains voltage, static electricity and radiations from certain devices. It can also be used to detect ghosts :P.
So lets get started...
Teacher Notes
Step 1: Tools and Components
This circuit is built on a breadboard and hence no soldering skills are required, the list of materials required are quite simple and easy to find on eBay.
  • Arduino Uno
  • Breadboard
  • 100k Resistor (or higher if you want a more sensitive device)
  • 330ohm Resistor
  • Jumper wires
Step 2: Circuit
The circuit diagram is really simple and can be found above. The sensitivity of the device can be changed by varying the values of resistance across the 100k Ohm resistor. The higher the value of the resistor, more the sensitivity, if you are going to detect static electricity I recommend using a 1M resistor.
Step 3: Code
The code for this tutorial can be found below
int inPin = 5; // analog 5
int val = 0; // where to store info from analog 5
int pin11 = 11; // output of red led
void setup() { Serial.begin(9600); }
void loop() { val = analogRead(inPin); // reads in the values from analog 5 and //assigns them to val if(val >= 1){ val = constrain(val, 1, 100); // mess with these values val = map(val, 1, 100, 1, 255); // to change the response distance of the device analogWrite(pin11, val); // *note also messing with the resistor should change // the sensitivity }else{ // analogWrite(pin11, val); just tuns on the led with // the intensity of the variable val analogWrite(pin11, 0); // the else statement is just telling the microcontroller // to turn off the light if there is no EMF detected } Serial.println(val); // use output to aid in calibrating }
All the code does is reads the voltages at the analog pin and turns on the led if a certain threshold voltage is reached. So the LED turns on when you bring the device near a mains supply.
Step 4: Testing
After uploading the code it is now time to test the device, for the antenna you could use a 3 inch copper wire. Power on the device make sure you use a battery as the power source to eliminate noise in the signal.
Next, take it towards your mains supply and you should see the LED light up. You could also try this around motors, lights and microwave ovens.
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
    5 Discussions
    robbyrnes101
    robbyrnes101
    Question 7 weeks ago on Step 4
    Hi, playing with various designs for emf meter. I want to work towards some kind of calibration. Do you please have an advice on how to calculate sensitivity with the resistor value?
    Thanks in advance
    Rob
    MuhammadL46
    MuhammadL46
    11 months ago
    Please how can i get the complete write up for this project
    Chrome98
    Chrome98
    1 year ago
    Works! But the resistors in your photos do not look like the specs in your materials list which I did use (and others). Thanks for a quick, fun build.
    Spichek
    Spichek
    3 years ago
    Easy way to kill Arduino.
    Better use any mft transistor. Like this
    http://www.observationsblog.com/sciencetechnologyexperiments/-static-electricity-detector-easy-to-make
    onion2
    onion2
    3 years ago
    Cool idea
