Electronic Appliance Protector in Less Then 100 Rupees
Introduction: Electronic Appliance Protector in Less Then 100 Rupees
About: I am a electronics hobbyist from india. Youcan visit my youtube channel "AviPrink" for more detailed information.
This circuit is fairly simple I guess . it can protect our many electronic appliances from high voltage damage.
Step 1: Video
Watch video for more info or visit my channel for more videos
Step 2: MOV (Metal Oxide Varistor)
This is the main component of entire module it costs 20 rupees. It is connected in parallel in circuit 1st pin to Phase and 2nd to Neutral. It can be rated various voltage threshold, suppose it is rated at 300v when voltage Increases above 300v then it acts like wire and consume lots of power or draw lots of current.
Step 3: Fuse
We all know about fuse ,when current flow increases above rated value then it blows instantly depends on type of fuse i recommend to use fast blow fuse for good results.
Step 4: MKP Capacitor
Capacitors are used in this circuit to Dump high voltage spikes, I Utilizes 0.47uF 275v MKP for my project.
Step 5: Connector
I have Used 2x connector in this project to connect Input and output Connections.
Step 6: 5mm LED Bulbs
Led Bulb are used for indication when circuit connected to power.
Step 7: 100k Resistor
100k Ohm resistor used in series with 5MM Red LED bulb, it limits the current for LED.
Step 8: Schematic
Working of this module is simple, when voltage at input increases above 300v (rated voltage of MOV) then MOV acts like a wire and draws lots of current so fuse got blow then aoe circuit becomes protected.
Step 9: All Done
Make your Own , let me notify in comment section below.
THANK YOU
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    MohitKKK
    MohitKKK
    Question 10 months ago on Step 4
    Is the capacitor is necessary. As in case of high voltage spike mov will short out and spike will pass through it and will not go through capacitor
