Electronically Controlled Voltage Regulator
its basically a PWM based voltage regulator.
for smooth regulting of high voltage devices(220v).
WORKING:-
if Duty cycle of pulse is 20 and the frequency is 50hz the voltage will be minimum and if we change it to 80% its voltage will be high and on 95% the voltage will be maximum.
Teacher Notes
Step 1: PCB of ECVR(electronically Controlled Voltage Regulator)
here is the simulated design of ECVR(electronically controlled voltage regulator) and its result.
and the PCB of ECVR.
Step 2:
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    2 Discussions
