Emergency Pocket S'more Kit
About: I love learning, creating, and dreaming! https://mamacita509.wordpress.com/
This is a pocket size S'more kit useful for those small sweet cravings. I used some pieces I found around the house along with an erector set I bought from goodwill.
Teacher Notes
Step 1: Supplies
Snacks:
  • Gram Crackers
  • Hersey's mini chocolate bars
  • large marshmallows
Miscellaneous Parts
Erector Parts
Step 2: Assembly
See image for part numbers
1. Bolt end of part 3 to top of 221 with nut and bolt. Do not screw to tight because you will need to be able to extend part 3.
2. Add magnet to inside of part 221. (The side with the nut). This will allow save you space.
3. Add magnet to inside of part 48b.
4. Adjust Skewer length.
5. Use 5 gage floral wire for rotisserie handle
6. Use a rubber attachment to attach handle to skewer
Step 3: Storage
In this order:
  1. 2 Gram Crackers
  2. 2 chocolates
  3. 2 marshmallows
  4. Erector pieces diagonally
  5. Candle
  6. Rotisserie handle and connector
  7. Matches
  8. Skewers
Step 4: Set Up
  1. Open up piece 3 and 221.
  2. Snap pieces 3/221 and 48b together. Magnets should be place in the correct places and it should take a few seconds to assemble.
  3. Put marshmallow on skewer and light candle and start rotating.
notes: It was a bit windy when I was roasting the marshmallow so I moved the marshmallow and skewer closer to the flame.
Pocket Sized Contest
Runner Up in the
Be the First to Share
    • Meal Prep Challenge
      Meal Prep Challenge
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
    6 Discussions
    Alex in NZ
    6 months ago
    Brilliant! Ideal for all those marshmallow-toasting emergency situations. Thank you for sharing :-)
