Energy Transfer With Two Tesla Coils
3,725
22
13
Introduction: Energy Transfer With Two Tesla Coils
About: I am a teacher researcher in mechanics and product design. I am also a manager of a web agency.
With these Tesla coils, you can light a led connected to a single wire
The energy is transferred to right from the left antenna.
  • The signal generator is plugged on black right coil (right antenna).
  • On the 2 antennas, energy is transferred by induction between black coil and red coil
  • Both red coils are joined by a single wire
  • Energy is transferred when the two antennas are in resonance
This project is based on Nikolas Tesla's research. I reproduced two Tesla flat coils, each surmounted by a sphere-shaped antenna, and connected to the ground. The device is shown above in the patent filed by Tesla in 1900 "apparatus for transmission of electrical energy". The realized device is a transmitter / receiver that transfers energy through longitudinal waves, also called "scalar waves".
For more scientific informations, see step 7.
Teacher Notes
Step 1: the Amazing Scalar Waves
  • When the receiver goes into resonance, we see on this video at the same time the leftled turn on, and right led is off.
  • When I bring the hand closer to the sphere of the receiver, the led gradually extends. The radiation of my hand disrupts the resonance of the receiver.
  • In the second video, despite the two metal cages, the receiver led on the left continues to operate without being disturbed buy Faraday cages.
  • The resonance takes place on the video, with a sinusoidal pulse of 6 volts at 9.3 MHz.
  • The resonance frequency will change, depending on the spacing of the antennas and the number of turns of the coil.
  • On this assembly, the red coil has 30 turns and the black 5.
  • On the first video, the antennas are spaced 15 cm, on the second 25 cm.
I translated the subtitles of the video into English, you can turn them in English.
Step 2: You Will Need...
Step 3: Make the Black Flat Coil
Make black flat coil around A and B supports
  1. Pinch the black wire on "B support"
  2. On the other side, pinch it into the groove
  3. Slot firmly "A support " with "B support"
  4. Wrap slowly 5 winding counterclockwise
Step 4: Make the Red Flat Coil
  1. Slot "C support" on the A and B support
  2. Slot "sphere support" on the stack of 3 parts, to block them.
  3. Wrap slowly red wire counterclockwise. There are approximately 30 winding, you'll need 5 meters of wire.
  4. Clip black wires on the fist slot of wago connector.
  5. Clip LED on the second slot of connector. Push the wires into the grooves
  6. Pinch red wire on "A support" tube
Step 5: Plug Spheres and Antennas Together
  1. Past red wire on sphere whith patafix
  2. Connect a wago connector on red wire
  3. Connect two antennas with a wago connector
  4. Cut the BNC 3G wire in 2 parts, connect on wago connector int the third slot. (note: a BNC wire is solded with DDS Signal Generator)
Step 6: The 4 STL Files
You have the 4 parts here. Use a 3D printer to make them. I used PLA without support.
You can find also my projet @thingiverse
Step 7: To Go Further...
I developed this model from the research of Nikola Tesla and the Professor Konstantin Meyl. Mr Meyl has studied scalar waves since 1990. You can find his books, publications, videos and devices from his site www.meyl.eu
The behavior of scalar waves with a Faraday cage is described in his publications.
Pr Meyl made a demonstrator with small electric boat which moves using the wireless transmission of power. The ground wire in water is connected to boat and secondary emitter. The primary emitter is outside water with the signal generator. The video
Electronics Tips & Tricks Challenge
Be the First to Share
    • LED Strip Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Clocks Contest
      Clocks Contest
    13 Discussions
    AntletherF
    AntletherF
    5 months ago
    Is it possible to do this with just a slayer exciter to power the primary Tesla coil?
    cedricr2
    cedricr2
    Reply 5 months ago
    sorry I do not understand. can you rephrase the question?
    AntletherF
    AntletherF
    Reply 5 months ago
    So there’s a type of circuit known as a slayer exciter. It one way to power a Tesla coil. I was wondering if it was at all possible, at least in theory, to use that for this experiment
    AntletherF
    AntletherF
    1 year ago
    Is this possible to do without the need of a ground wire between them, thus transmitter can be miles from the receiver and it still works? Thanks!
    cedricr2
    cedricr2
    Reply 5 months ago
    without ground, you can't transmit nothing. ground is essential
    cedricr2
    cedricr2
    Reply 1 year ago
    It is necessary that there can be a link between the 2 coils. we use here a ground wire. Nikolas Tesla linked his transmitter and receiver towers by the ground. This requires power and a large installation.
    cedricr2
    cedricr2
    Reply 5 months ago
    Hello
    planes are suspended with metalic wire, there is a ground connection here
    AntletherF
    AntletherF
    Reply 1 year ago
    Alright, thanks. It’s just I’m trying to replicate the experiment done by Meyl where he powered planes using scalar waves
    Gadisha
    Gadisha
    1 year ago
    Very interesting project!
    cedricr2
    cedricr2
    Reply 5 months ago
    thanks !
    AntletherF
    AntletherF
    11 months ago
    If the tesla coils were grounded to earth, how far could they go, and would it depend on their frequency?
    cedricr2
    cedricr2
    Reply 5 months ago
    we need a strong power for grounded to earth method. Distance does not affect scalar waves. Nicolas Tesla had made a transceiver transmitting energy, with a distance of 40 km. But with hundreds of thousands of volts !
