Epoxy River Rock Table That GLOWS
3,913
61
About: Hi Everyone, I'm Jeremy Hoffpauir. I write instructables about unique DIY woodworking and home improvement projects. I use unique design elements with a rustic coastal style in my creations such as epoxy...
In this instructable, I show you how to make a transparent epoxy river desk with rocks that glows in the dark.
This epoxy river table tutorial contains resin and woodworking techniques/tips I use to make and sell my handcrafted tables. So, let’s get started!
Supplies:
At the end of this instructable, I provide a simple formula to use to determine how much resin you need for your project. Be sure to use that formula before purchasing epoxy.
Epoxy Resin (Deep Pours)
Fluroscent Blue Glow Powder
Blue Acrylic Rocks
Rubio Monocoat Oil Plus 2c
EurKitchen Butane Culinary Kitchen Torch
Large Mixing Containers
Resin Mixing Stick
Silicone Caulk
F Clamps
Nitrile Gloves
26" Hairpin Legs
Black LED Lights
Soldering Kit
Hot Glue Gun
GoPro Hero 8
Panasonic Lumix G7
Tripod
Pinless Wood Moisture Meter
Festool TS75 EQ Plunge Cut Circular Saw with 75-Inch Track
Festool MFT/3 Table
Milwaukee Electric Tool 25Ft Tape Measure
Uline H-150 2-Inch Tape Dispenser
Festool RO 125 FEQ Rotex Sander
Festool RO125 FEQ StickFix Sanding Pad, Supersoft
Festool RO125 FEQ StickFix Polishing Pad, Hard
Festool P120 Grit Rubin 2 Abrasive
Festool P80 Grit Rubin 2 Abrasive
Festool P150 Grit Rubin 2 Abrasive
Festool P180 Grit Rubin 2 Abrasive
Festool P220 Grit Rubin 2 Abrasive
Festool 5 in. RO125 Polishing Sheepskin
Buffing Pad Cleaning Spur
Dewalt Grinder
50 Grit Metal Sanding Disc
Gunpla 48inch Magnetic Spirit Level
Festool Router OF 1400
Whiteside Surfacing router Bit
Festool Roundover Bit
Festool CXS Compact Drill Set
Horusdy Super Strong Centre Punch
Swanson 9" Torpedo Level
Often times, I experiment with many different products and tools while working with epoxy resin. For your convenience, I’ve compiled a complete list of my favorite epoxy resin material and tools.
Teacher Notes
Step 1: Custom Design Process
In order to provide a bit of background, this transparent epoxy river desk was a custom order from one of my customers in California. As I do with all my custom table orders, I create a 3D model of the item and send it to my customer for approval.
My customer requested a reclaimed cypress wood desk with a glowing epoxy river and embedded blue rocks. The dimensions of the desk were 48"x28"x28"x1.75" (LxWxHxThickness). Furthermore, this table resembles my epoxy resin river table with blue fire glass, but a bit larger in size.
Epoxy River Table: Fire Glass vs Acrylic Rocks
I chose to use blue acrylic rocks instead of fire glass for this desk for 3 reasons.
  1. Blue fire glass reflects light and the glow powder needs natural or artificial light to charge.
  2. The fire glass I use is sharp and needs to be handled with care.
  3. My saw I trim the ends of each table I make at the end of my projects and my saw blades don’t like to cut glass.
Ultimately, the acrylic rocks worked much better than the fire glass. It also produces a very unique look which is more natural and clean.
Basically, choose fire glass if you like bling. Otherwise, choose acrylic rocks if you like a more natural, organic look that's easier to work with.
Step 2: Mill Wood
The only stationary tool I have in my workshop is my bandsaw. Due to various reasons, I sold all my stationary power tools and elected to use mobile power and hand tools for all my projects.
So, my local hardwood dealer mills the wood for me when I purchase it for a small fee. If you want to get into woodworking, you don't need to spend thousands of dollars on a jointer, planer, drum sander, etc.. Most of the time, hardwood dealers are more than happy to mill the wood for you for a small fee.
First, they resawed piece of reclaimed cypress into two 2″ slabs.
Then, they ran it through their jointer to get a straight side.
Next, the 2 wood slabs were ran through our planer to get a flat surface.
Step 3: Cross Cut and Wood Moisture Level
Once I arrived home, I cross cut each 2″ cypress slab. To ensure a straight cut, I referenced the flat side agains the rail on my MFT3 table and cut one side.
Then, I flipped the wood over and measured from the side I cut first 3 inches longer than the final dimensions.
Before I begin any woodworking project, I check the wood moisture level with a wood moisture meter. Wood is hygroscopic which means it gains or loses moisture depending on the relative humidity (RH) of the surrounding air. Essentially, the correct moisture level prevents the wood from moving (shrinking or expanding) after the completion of the project.
Step 4: Best Wood to Use for Epoxy River Tables
Any hardwood works best for an epoxy river table.
Hardwood species such as walnut, oak, maple, and many more are very dense with tight grain patterns. Consequently, this reduces air pockets (bubbles) by limiting the amount of epoxy resin which absorbs in the wood.
I use cypress wood on many of my projects because it is plentiful and comes in many variations. My favorite cypress to use for river tables and epoxy bar tops is sinker cypress.Although cypress wood is considered to be a hardwood species, it is not particularly dense like most hardwoods.
Step 5: Epoxy River Mould
There are many ways to make an epoxy resin mould and I’ve tried most of them.Ultimately, I build my resin moulds based on what I have available in my shop.Most often, I have scrap wood, packing tape, and furniture wax available. So, I used these materials to build the resin mould.
First, I place the wood on a flat and level surface. Next, I completely covered the scrap particle board with packing tape and covered it with furniture wax.
Step 6: Sand Live Edge Wood Slab
Since the cypress wood slab was resawed and planed by my hardwood dealer, I only sanded the live edge.Most live edge wood slabs contain bark or debris which need to be removed.
A soft sanding pad with 220 grit sandpaper works well to clean up the live edge without changing the shape or natural contours.
Step 7: Filling Cracks With Epoxy
While inspecting the wood slabs, I noticed a wood crack on the underside of the cypress slab.
I decided to mix 12 ounces of epoxy resin along with a 1 drop of brown dye and 1 drop of black dye. These colors matches the small streaks of dark grain and the live edge.
First, I filled the wood crack with epoxy resin.
Additionally, I filled the wood knots with resin as well.
After heating the resin with a torch, I moved the excess resin with a plastic spreader.Essentially, resin gets thin when heated which enables it sink deeper in the wood crack.
Step 8: Secure Slabs to Resin Mould
As a final step before the resin pour, I positioned the cypress wood slabs on the resin mould.I like to position the slabs 2″ wider than the final dimensions. This allows me 1″ on each side to trim later in the project.By the table being wider and longer than the final dimensions, I don’t have to worry about damaging the ends or sides during the build process.
Next, I cover 2 pieces end pieces of scrap wood with tape wider than the width of the river. I secure them to each end of the river
Then, I seal around the perimeter of each wood slab to prevent leaking.
Lastly, I use scrap 2x4s with clamps to secure the wood slabs in place. I make sure to perform this step immediately after sealing in order to compress the silicone caulk for a better seal.
Step 9: Epoxy Resin for Deep Pours
Basically, the 2 main types of epoxy for table projects are classified by the depth, or thickness, that can be poured at one time.This classification method suffices for epoxy river desk or table projects, but it is grossly oversimplified.
Deep pour epoxy cures slower and normally mixes at a 2:1 mixing ratio.Thin pour epoxy cures quickly and normally mixes at a 1:1 mixing ratio.Furthermore, deep pour epoxy speeds up the build process by reducing the number of pours. For this project, I used Liquid Glass 2.0 Superclear Epoxy as it allows for 2″ to 4″ pours.
The thickness variation of 2″ to 4″ accommodates various environmental factors such as temperature and humidity. Warm, humid environments speed up the curing process while cool, less humid environments slow down the curing process.Remember, slower cures allow for deeper pours while faster cures do not.
Step 10: First Epoxy Pour
For the first epoxy resin pour, I used multiple mixing containers and a total of 192 ounces of epoxy.
The multiple mixing containers make it easy to properly mix large batches with 2:1 mixing ratios such as this epoxy.
First, I poured 64 ounces of part A in 2 containers for a total of 128 ounces of part A.Next, I poured 32 ounces of part B in 2 containers for a total of 64 ounces of part B.
Then, I poured 1 64 ounce container of part A and one 32 ounce container of part B into 1 large mixing container.
I repeated the process for the other containers. So, I ended up with 2 96 ounce containers for a total of 192 ounces.
As a quick epoxy mixing tip, always mix the material until it turns clear as this is a sign it is ready to be poured.The container at the top of the picture below has not been mixed.Conversely, the container below it has already been mixed and very clear.
Step 11: Add Epoxy Glow Powder
Once each container was mixed, I added blue epoxy glow powder to each mixture.
This fluorescent blue glow powder is blue while at rest and produces a blue glow. Other glow powder colors tend to be a pearl white at rest and turn colors while glowing.
First, I poured roughly half of the 8 ounce bag in one resin batch.
The epoxy glow powder clumps together at the bottom and releases bubbles which produces a satisfying look.
I mixed the material in each container for roughly 3 minutes.My favorite epoxy mixing technique starts with 3 circles clockwise. Then, 3 circles counterclockwise followed by 3 bottom scrapes.
Once I finished mixing the epoxy and glow powder, I poured half of one container in the other.Then, I mixed the half full container to make sure no blue glow powder stuck to the bottom.Next, I repeated the process with the other container.
Step 12: Epoxy Glow Powder Base Layer
After the glow powder and epoxy were fully mixed, I poured each container to from the base layer of the transparent epoxy river desk.
Next, I removed the bubbles with my mini torch. Surprisingly, this deep pour epoxy did not produce many air bubbles at all.
The picture below shows the blue epoxy glow powder glowing in the dark after the first pour.
Step 13: Add Acrylic Rocks
As I mentioned earlier in this DIY tutorial, I used acrylic rocks for this epoxy river desk.The acrylic rocks will be covered with transparent clear resin to create a unique visual – especially when the epoxy river desk glows.
After the base layer cured for 48 hours, I spread the blue acrylic rocks on top of the epoxy glow powder layer.
This transparent epoxy river desk with rocks required to bags of blue acrylic rock to cover the surface of the river.
Step 14: Second Epoxy Pour
After I evenly spread the acrylic rocks and they were about 1″ below the surface of the table, I started the second pour.
First, I labeled my buckets from the first pour.It may be an issue if I use the part B bucket from the first pour for part A in the second epoxy pour.
Next, I mixed 96 ounces of resin using the same procedure as the first epoxy pour.I poured the resin on top of the acrylic rocks.
While pouring the resin, I noticed the acrylic rocks floated to the surface. I’m not sure why I didn’t anticipate this happening.Consequently, I will need to stop about 1/2″ from the top and perform an extra pour to reach the top of the wood slabs.
A paint stick worked perfectly to spread the rocks evenly across the transparent epoxy river desk with rocks.
After I spread the rocks, I used my mini torch to remove the small amount of air bubbles.
Since the acrylic rocks float, I used my level to make certain I didn’t have a protruding rock on the surface. Also, I used the 4′ level to make sure the epoxy river desk was level.
Step 15: Final Epoxy Pour
After 3 full days, I prepared the final epoxy pour.
I mixed 192 ounces of resin and filled the remaining 3/4″ until the epoxy was level with the surface of the wood slabs.
This epoxy covers the surface well and it is very clear. I really enjoyed working with it.
Step 16: Flatten Wood Slab
Although I took great care to ensure the epoxy river desk remained level, I needed to flatten the wood slabs with my router.
Ideally, this step should not be needed; however, I poured a too much epoxy. Rather than sand the epoxy and risk burning the epoxy, I chose to use my wood slab flattening jig and router to take off 1/16″ off the top.
My wood flattening jig consists of 2 90 degree aluminum corner pieces with a 2×2 wood block on each end.The wood blocks are 1/8″ wider than the base of my router to prevent sticking and kickback.
Step 17: Remove River Desk From Mould
After I flattened the transparent epoxy river desk with rocks, I removed it from the epoxy mould.
To my dismay, I discovered epoxy leaked under the desk. Luckily, the epoxy leak was not bad.
A small hole caused the leak, which was a result of not sealing the wood to the mould properly.
The epoxy would not be difficult to remove. However, the temperature outside is in the upper 90s.Needless to say, I rather be working inside under the cool air from my DIY mini split.
Step 18: Remove Resin With Grinder
I removed the resin from the underside of the epoxy river desk with my grinder and 50 grit metal sanding disc.
Many people ask me how to remove cured epoxy from wood. Essentially, the best way to remove cured epoxy is with a grinder and a few 50 grit metal sanding discs.
Obviously, this method to remove cured epoxy from wood makes a complete and utter mess.However, it gets the job done quickly and efficiently.
Step 19: Sand Epoxy River Desk
After I finished removing the cured epoxy from the underside of the epoxy river desk with rocks, I started sanding.
First, my Festool RO 125 makes sanding any epoxy or wood project much easier.The Festool RO 125 is a dual-mode sander with a coarse and fine setting for sanding a variety of surfaces. Also, it works great as a polisher as well.
Since this transparent epoxy river desk was flattened with a router, I started at 40 grit in coarse mode with the regular sanding pad.The ‘C’ stands for coarse mode and the ‘F’ stands for fine mode: 40C, 60C, 80C, 100C, 120C, 120F 150F, 180F, 220F, 320F.
Most importantly, I use a pattern when sanding with each grit to prevent swirls and other sanding mishaps.First, I choose a 3 foot by 3 foot section.Next, I sand from east to west and overlap about an inch.Then, I sand from north to south with the same amount of overlap.Finally, I sand in roughly a 6″ circle and move to the next 3′ by 3′ section.
Step 20: Trim to Final Dimensions
Once I finished sanding, I trim the epoxy river desk to the final dimensions.
The final dimensions of this transparent epoxy river desk is 48″x28″x28″x1.75″ (LxWxHxTH). First, I cut one end using my Festool TS75 track saw to get a perfectly straight cut. I cut the table down to 50″.Any hand saw with a straight edge will work.Also, I use an older saw blade to cut resin as it dulls saw blades very quickly.
Next, I measured from the side I just cut from each side of the table and made a mark to the final dimension of 48″.I laid my track on the 2 marks, clamped the track, and made the final cross cut.
Then, I trimmed off 1″ from each side using the same procedure.
Step 21: Dress Up Epoxy River Desk Edges
To soften the edges of the transparent epoxy river desk with rocks, I used a router with a 1/2″ roundover bit.An orbital sander or block plane works as well to soften table edges.
After I performed the roundover, I removed the dust from the table top.
Step 22: Install Hairpin Legs
I prefer to attach the legs and complete all work on the underside of the table before applying the finish.
First, I flipped the table over and placed the hairpin legs on each corner. Next, I used a nail punch to mark the holes.
Then, I marked the depth of the screw with a piece of tape on a 1/4″ drill bit. I used my drill and gently drilled on the marks up to the line.
As a last step, I placed the hairpin legs back on the table and slowly screwed them in place. I find it best to tighten the 2 inside screws first and then the 2 outside screws.
Step 23: Install LED Strip Lights
In the event the transparent epoxy river desk does not have access to light, I installed black UV LED strip lights on the underside.Essentially, the black UV LED lights exist to charge the blue epoxy glow powder.
First, I placed the LED strip lights to the underside of the table where the epoxy river and wood meet.I used the clips supplied with the UV LED strip lights along with hot glue to secure them in place.Also, the clips helped me secure the end of the LED strip lights near a hairpin leg. This will hide the power supply and wall outlet wire.
Next, I used a pair of scissors to cut the LED strip lights between the copper dots on the cut line.It is important to cut the LED lights at this location in order for the excess to function and for soldering purposes.
I flipped the transparent epoxy river desk over and didn’t like the look of the one LED strip.
Consequently, I decided to add another LED strip on the opposite side.To join the lights together between the 2 sides without having lights cross the river, I soldered black and red wire to each LED strip.
Step 24: Solder LED Light Strips
My helping hands held the 2 wires in place while I soldered them together.I soldered the black wires together and the red wires together. The black and red wires were long enough to stretch across the epoxy river.
Next, I pushed the sleeve over the solder and brazed it with my mini torch.Ideally, a heat gun works best to shrink the electrical sleeve as the torch could damage the wires.
Then, I secured the second light strip using a hot glue gun to the opposite side.
After testing both LED strip lights work, I tested the lights, flipped the table over, and installed the rubber hairpin leg feet.
Ultimately, I think 2 LED strip lights look much better than one.
Step 25:
Finally, time to apply finish to this epoxy river desk with rocks.For this table, I used Rubio Monocoat Oil Pure.
My 3 favorite products produce a natural, matte finish while protecting the wood and reviving the transparent epoxy.
  1. Rubio Monocoat Oil Pure
  2. Odie’s Oil
  3. Festool Wood Polish
Each of these finishes work great on wood and epoxy surfaces.Furthermore, they are all a 1-step finish. In other words, only one coat is needed if applied correctly. I’m not a fan of the glossy epoxy finish because I like to feel the texture of the wood.In fact, I believe the best finish gives the appearance there is no finish at all. First, I mixed rubio monocoat according to the instructions and poured it on the table.This stuff goes a long way, so I didn’t mix too much.
Next, I used a plastic spreader and worked the material across the epoxy river.
Also, I allow a small bead of finish to drip over the edge of the table to cover the sides.
Then, I used a microfiber towel to remove the excess as best as I could.
Finally, I used my Festool RO 125 with the polishing pad and sheepskin in coarse mode to buff away any finish left behind by the towel.
As a quick tip, I highly recommend purchasing this spur tool to clean any polishing or buffing pad.I simply turn on the machine and place the spur tool on the sheepskin or pad.
Step 26: Epoxy Resin Calculator
How much epoxy resin do I need for a river table? The formula to use to calculate how much epoxy resin needed for a river table is:
Gallons: Volume(Cubic Inches) * 0.004329
Quarts: Volume(Cubic Inches) * 0.017316
In order to determine the volume in cubic inches, measure the widest part of the epoxy river and use the following formula:
Volume (Cubic Inches) = (Length (inches) x Width (inches) x Depth (inches)) + 10%
Please note, the 10% compensates for spills and to purchase more than the amount needed. Obviously, the 10% is optional.
Step 27: Conclusion
In conclusion, I hope this transparent epoxy river desk with rocks project provided you with value.
Additionally, I hope the tips and techniques you learned help make your next DIY river table project easier.
Let me know in the comments what you think about this project. I read and respond to each and every comment and/or question.
Lastly, checkout my handcrafted items for sale as well as my wide selection of DIY downloadable plans to serve as a companion for your next project.
Follow Me
YouTube - I have plenty of video tutorials
Instagram
Facebook
Twitter
Pinterest
Furniture Contest
This is an entry in the
Furniture Contest
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
    2 Discussions
    rocket radhi
    7 days ago
    Nice night glow effect, we don't have to hit ourselves during night :P
